I am in the midst of an outdoor (commissioned) project for a branch of UNC-Asheville called the Kellogg Center for Craft, Creativity and Design -- two outdoor Bulletin Board Kiosks I designed for the entrances to their public Art Trails.
You'll notice the large doors that cover the bulletin boards (two per side, they measure 42-3/4'' by 39-3/4'' and have Lexan glazing). I wanted maximum window size, but they can't sag and need to be secure. I chose to make the doors from 2'' wide x 3/4'' thick white oak with half-lap corners -- getting 4 square inches of glueing surface (glazing sits in a centered saw kerf in this frame).
After inserting the Lexan and squaring the frame, each corner was secured with 5/8'' brads while the glue dried. A strong joint, but these needed to be stronger and a pegged joint is the answer.
I made a jig from a half-lap practice piece and drilled two 3/8'' holes with a Forstner bit. The jig assures consistent hole spacing -- it is oriented to avoid hitting the brads -- I precut 13/16'' long oak dowel pegs, glued them and hammered them home.
These joints aren't going anywhere! For consistency, the grain in each peg is oriented in line with the outside of the door frame; it will be cross-grain on the inside. A little sanding and the doors are ready to install in their two sided frames, also made of white oak.
More to follow...
More to follow...
