I needed a 10" radius sanding block to radius the finger board on the bass guitar I'm making. The finger board radius must be the same at the nut and bridge or the guitar will not play correctly. The last guitar I made was at my buddies in northern IL and he had a set of store bought - 8" long wooden blocks. Instead of popping $15.95 plus SH and time it takes for UPS to deliver for a 10" diameter sanding block. I decided to venture out to the shop and make a 10" radius sanding block.
After thinking about it for a while, it dawned on me I have a 10" tablesaw . So I squared up a length of 2x4 poplar and clamped two parallel 1x4's to the table saw at about I'm guessing 30 degrees with the center of the blade. With the blade just barely rasied above the table, I very carefully and gingerly pushed the length of 2x4 through the sawblade. Like magic it worked there was a slight radius in the middle of my block, no kickback and when through fairly smooth. I thought awesome so I continued to raise the blade a little at a time till my radius was 2 1/2" wide. The radius looked awful small to me, way less than 10", so I checked it and I was right... it wasn't 10"
I pulled the blade off the table saw and measured it sure enough it was 10"... uggg... what did I do wrong? 10" is 10", isn't it? uggg...
Then it occured to me :widea: what if I push the block parallel to the blade, 10" is 10" it should be right. So I used my square and lined up the 1x4's exactly 90 degrees to the miter slots and and the center of the blade and tried it again with another length of squared up poplar 2x4. Low and behold it worked, dead on 10" diameter So I cut the block to 11" long and fastened a full sheet of sand paper with some push pins to the sides of the block and started sanding. It worked like a champ, I couldn't have been any happier, now I have a 11" long block instead of 8", that's just as good if not better than store bought
Pic of my 1st attempt at what I'm guessing to be around 30 degrees - most importantly it's not a 10" diameter.
My 2nd attempt at 90 degrees to the saw blade - dead on 10" radius.
Now I have a question, for those into solving mathematical story problems. Does anyone know the formula for the radius produced from a given saw blade diameter at various angles?
Thanks
Thanks
