Looking for a Drill Press …Found One!!!
Flute Maker
I am looking for a drill press that would be set up just to use with a mortising attachment. An older good one that someone wants to part with would be great.I’m just looking for now and don’t have a lot to put in one. This is kind of a future project. TIA!!!
Ed Fasano
Ed
I have a clean and complete Delta mortising attachment (circa 1992) that I can/would part with for $80, including 1/4 and 3/8" chisel/bits and an unused pair of Lee Valley conical diamond hones. Probably uneconomical to ship. I'm in Kernersville. I used it a few times on my (then) Delta press and later on my Steel City, and I believe it will fit most common import presses with a 66mm quill diameter. This set does not have a case or extra collars for smaller quills.
Traceg
Trace
Thanks Ed. Mike, I went down and measured the quill diameter on the non-moving portion where I would imagine any attachments would mount to (the press currently has a depth gauge mounted in this location). The quill diameter on this benchtop model appears to be ~52mm (~2.05"). Looks like the Rikon and other mortising attachment sets offer a series of bushings that allow you to use those attachments on just about any quill size. Just wanted to point that out in case the nice attachment that Ed has will only fit a 66mm quill size.
Ed Fasano
Ed
Yes, it looks as if some newer sets include a variety of collar adapters for varying quills.
Flute Maker
Hi Ed
I have already picked up one from another guy on here… It was a great deal. I appreciate it though! Thanks!!!
Flute Maker
Hi Ed
