After being in the Corps for 22 years I learned that if you do not write down your after action items you are doomed to repeat your mistakes. Now that the summer is over and the majority of the projects are complete.
Here goes:
Here goes:
- Measure your work, mark the wood, remeasure and check, cut wood, check wood for fit, throw wood away and go get glasses and repeat all steps.
- The amount of chemicals that it takes to clean up something is in direct proportion to the amount if it you spill on your project.
- Was that 25 3/8 or 23 5/8? Write stuff down or you will forget it on the way to the saw.
- The wife is always right no matter what.
- The amount of times she asks if you know what you are doing is directly related to the difficulty of the task that you are doing and thus raises the frustration level
- If you ask a kid to hold a tape, assume the measurement is wrong
- Guards are there for a reason other than to get in your way. USE THEM.
- A piece of 1”x1”x4’ maple will fly 10 feet and pierce a truck window. See 7 above.
- Cussing will not make a board longer nor shorter.
- A lathe is a dangerous piece of gear in the hands of a novice. Home Depot has some nice maple balusters!
- If your wife stops working your honey do list will never be done.
- If it looks like it will fit most likely it won’t
- No new house is even remotely perfectly square. Buy an angle gauge
- The $3.99 w/coupon sander from Harbor Freight is just that. A $3.99 sander!!
- The dog will never come in to the garage until you have every flat space taken up with boards with fresh wet poly on them, then he shakes!
- Never leave a teenager who has been on YouTube alone with a belt sander
- In Onslow County 16” on center is just a suggestion!
