Kitchen done
Willemjm
Willem
My kitchen is finally done, had to wait for the builder before I could do the final trim.
I'll post up pictures and some notes for those interested in doing this themselves in the future.
Except for the slides and the hinges, everything else came out of my shop, which was still a work in progress, hence slowing me down a little.
Build time, 6 weeks.
Installation 1 week.
I got three bids for this before deciding to do it myself, from high to low they came in at 39k, 34k and 31k.
My costs for all materials, slides, hinges, finishing materials was around 5 1/2k and I had to hire occasional help to handle the heavy stuff, moving around and help install. That came to roughly 1k, so total costs was around 6 1/2k
Lumber used, Black Cherry, for the doors, face frames, molding, drawer fronts, columns etc. Case work was a mix two and one side pre-finished 3/4 Maple ply. Drawers and shelving trim were American Beech, with pre-finished 1/4 Maple ply bottoms.
The range hood, still has it's protective plastic in place, we will clean up later.
184327
No shoe molding used, I scribed the toe plates to the floor and used bracket feet for extra trim.
Finish was two part conversion varnish sprayed with a compressed air HVLP gun.
184328
The center island columns were turned on the lathe, 16/4 Cherry glued up from 8/4 boards.
184332
The shelves are pre-finished Maple ply, with a solid American Beech trim edge. They are all adjustable. The doors and drawer fronts are raised panel (not bevel panel, the panels stand proud of the frame)
184333
The upper case base molding was milled on my teeny wheenie 3hp Grizzly shaper, one pass with a power feeder.
184334
The upper case crown molding was milled in four passes on my 7.5 hp shaper, using a molding head and home custom ground cutters. The front took two passes to get the different profiles and the back took two passes to get the crown angles on the back. For the front I had to make a special fence/jig so the power feeder could handle it.
184335
Some of the shelves are on slides, using 175 degree no protrusion door hinges.
184336
The best space utilization I could get for this dead corner, was a massive pantry, using pie-hinged doors. I had to build, assemble, take apart and re-assemble in the house due to the size.
184337
Tip-out tray in stainless, for the sink false drawer.
184338
The trash cans are as big as I could fit under the island. They slide on 135lb Blum Blue motion smooth as silk.
184340
Drawer dovetails were milled with a Leigh dovetail jig. There are no nails or screws in the drawers, everything glued up.
184341
Cope and stick was done with a 1/2" tonge and groove, as opposed to the standard 3/8", to give a little extra glue area.
Some more notes:
All the lumber was milled from rough sawn 4/4, so my face frames and doors ended up around 7/8" rather than the standard 3/4" used in cabinet construction. I did not want to waste this pretty Cherry into more sawdust. Each part was cut from the rough sawn and then jointed, and planed perfectly flat. Compared to dimensioned lumber used by most cabinet makers, my doors turned out completely flat. When placed on a flat surface, it was almost as if air pressure held the door panels down.
There was no tint, or stain in the finish. IMHO, if one can get high quality Cherry it is gold and the natural color should be preserved.
Finally, my builder is trying to line me up for three kitchens, but I think I will be giving that a rain-check. It is not a one person job and I don't want to employ people. Also, I do not find cabinet work as rewarding as taking the time to design and build a high end piece of furniture.
Thanks for looking and reading.
Bear Republic
Stunning, your hard work really shows. Hands down from to bottom that's a lot craftsmanship. You certainly too in the challenge and surpassed it. I know you must be as proud of it as if it was a child. What does the Mrs feel about it?
Wow, that came out great, probably better than any builder would have done it. A lot of work, but effectively your hourly rate was $100, that's not bad. But I can understand not wanting to do more of these, cabinetry is heavy and repetitive.
Never sell the house. But if you do, make the owners sign a contract they will never paint the cabinets! :cool:
Jim M.
Woody
Willem, that is absolutely incredible, wow! Thank you for sharing the journey, it was fun to watch the build.
Graywolf
Board of Directors, President
Richard
It turned out great! Some real nice touches throughout.
Looks great!!! I am jealous. I redid our kitchen last year but I used purchased cabinets because that was the directive of my then wife. I don't know exactly what I paid but I am pretty sure it was over $20K. I paid extra to get plywood boxes and it was decent plywood but only 1/2 thick. I think they are KraftMade. I built one kitchen many years ago but it was not nearly as nice as yours.
I like the stainless steel fake drawer in front of the sink. Do you remember where it came from?
