Just picked up some machinery...
shawn
shawn
I just acquired a few machines, one of which is a S.A. Woods f99 16" jointer. I finished reassembly yesterday, except for the motor, its locked up. The cutter head runs on Babbitt bearings and I was wondering if anyone here has experience with them, i.e. lubrication. the head seems snug enough, though when itook the caps off and removed the shaft, there seemed to be grooves in the bottom of the bearing. I thought these might be for lubrication purposes but I'm not positive. The research I've done so far leads me to believe the bearing should be "solid/fully formed" around the shaft. Maybe I need to get the bearings re-poured? Any insight?
Thanks
shawn
shawn
shawn
:gar-La; It was disassembled, though it took all of two of us to load the base...
Roy G
Roy
Shawn, do the grooves look like they were cut, or do they look like they were worn in? Were there any shims when you took off the bearing caps? When you pour babbit, you pour it around the shaft, usually with lampblack on the shaft to provide a little clearance. When you assemble the bearing caps, you place some shims between the halves of the cap to provide room for the lubricant. As the bearing wears, shims can be removed. If the shaft looks good, your bearing is probably still serviceable.
Roy G
Jim Roche
jim
Hey Shawn,
Nice "get" there! Sounds like Roy is steering you down the right path. Another reference is OWWM.org, they're a friendly bunch over there as well and can help you along the way getting the old girl back in tip-top shape.
Good luck on your refurb, she'll serve you well.
shawn
shawn
shawn
bearing pics
awldune
Sam
If you are not already a member at owwm.org you probably should check there. Those guys will get you sorted out with your bearings.
My thought: Why'd you waste good money for a jointer with a locked-up motor?
Thanks
Graywolf
Board of Directors, President
Richard
Shawn, I'd be interested in following your progress, beautiful old machine.
I have bought machines with quite easily repaired problems at deep discount due to the owner either not knowing how to repair or not wanting to bother. It is a good way to save a lot of money for a little effort.
I don't see anyway this is wasted money or effort. To suggest so is is not helpful nor encouraging.
I was just looking at the Grizzly latest sales flyer and checked on their 16 inch jointer with 5HP 220v single phase motor.
http://www.grizzly.com/products/16-Z-Series-Jointer-w-Spiral-Cutterhead/G9953ZX
$8000.
5hp motor $455
http://www.grizzly.com/products/Motor-5-HP-Single-Phase-3450-RPM-TEFC-220V/H5390
Don't know what Shawn paid but i would say he probably got a great deal and the locked up motor is inconsequential.
ste6168
Shawn, you're right up the road from me, cool machine! Would love to see it in action once you get it fully restored/running!
I'm not discouraging Shawn. It's my different point of view to an interesting discussion.
Grimmy2016
Where does one find such amazing finds....? I have been looking for a bigger (not as ginormous as yours) and keep hoping to find a darling steal on Craiglist but that hasnt happened yet.
Graywolf
Richard
Scott careful what you ask for, that kind of thing happens to me when the active desire for finding said item is ending but my intentions are still to get one. For some reason it falls in your lap.
