Hi Everyone
Well the time is fast approaching for our upcoming Intarsia Class so I thought I would touch base with everyone who will be attending with a list of items that will be needed to create the Rose Box Intarsia Project.
Scroll Saw--If you have one, bring it. If not I think the saws supplied from the club trailer may be enough. I will bring my old Craftsman saw also.
#3 Scroll Saw Blades Because we will be working with 1/8" and 1/4" woods #3 skip tooth will be a good choice.
Dremal tool--We will use a 1/2" sanding drum with 60 grit drums for most of the rough shaping of the Intarsia pieces.
5/64" high speed cutter will be used during the box assembly.
Hand held belt sander. I use this with 80 grit and 120 grit belts for sanding box components and fine tuning the bookmatched inlays. I will bring mine
Battery drill with 1/8" and 5/64" drill bits used for hinge installation.
Packing Tape-Will be used for box assembly.I will have 3 dispensers and tape available.
Yellow glue- will be used for box assembly.
CA glue- the thick stuff will be used for gluing the intarsia onto the backer board -CA accelerator if you have it.
Small Back Saw will be used for cutting the accent strips during box assembly,I will bring mine.
36" ruler or other straight edge-used for box assembly.
Sanding Block and sheets of 100 and 220 grit paper for all finish sanding.
Spray Poly- satin finish
Mineral spirits- used for pattern removal.
Cloth rags for wiping on mineral spirits and wiping off poly.
Large black marker- used to conceal gaps in the intarsia.
Small framing square- used for box assembly
Safety glasses and magnifying glasses if you're like me and can't see small stuff.
I will be bringing most of the stuff on this list but if you have it , bring it .
Really looking forward to meeting with everyone.
Also, follow this link to my blog-Buffalo Box Intarsia-A work In Progress to get a good idea how we will be" Having Fun, Gettin it Done.
https://midlothianwoodworks.wordpress.com/buffalo-box-intarsia-a-work-in-progress/
