I have looked at a BT3100-1 that looks like new and am wondering about should I buy it or not. I now have a 20+year old Shopcraft that I made a roll around stand for and this is nicer but is it worth $175? I don't use my current saw daily or even weekly at times but it is a pain to use because of the fence and some other things.
So to all of you that have one or have had one what is a good price or should I just keep looking around for something better?
I had the same saw, and eventually upgraded. Some thoughts:
Pros:
-Splitter moves with the blade
-Sliding table
-wing for router (on mine - may not be standard)
-Lightweight, very poratble
-Handled *most* everything I threw on it, including 4x8 sheets!
-Cost effective
Cons:
-A little under powered. Had a little trouble with 4/4 stock and a lot with 8/4. Smaller stuff goes through just fine.
-Some of the common jigs you read about in WWing magazines, will need to be identified.
-There are shims needed to keep the blade positioned correctly to align with the riving knife. They can come off and fall down into the blade guard under the table. (I ended up taping mine together, worked great!)
-As mentioned, the shims to raise and lower the blade can bind. I had to replace mine, and I ended up buying two sets - just in case.
Overall:
If you are not going to be using it on heavy stock, it is a great machine. If sawing stuff 4/4 or thicker, I would say save up and look for something a little beefier. There are some nice setups and jigs on the BT3000 site. First thing you do, should you get it, get a nice blade. Once I got rid of the stock blade and put a nice Freud blade on, it worked fantastically. Honestly, except that I knew I would have projects using thick stock, I would have kept it. But I am not a particularly patient person and the slow feed rate for that large stuff was driving me nuts!
