Trying to figure out a way to cut about a 60 degree angle along the length of a piece of wood that is 2.5” tall, 16” long, and 7” wide. Table saw only goes to 45 degrees and if I stand the piece up to run it through at 30 degrees the blade wouldn’t go all the way through the cut. Can this be done on a band saw? Any other methods I’m not thinking of?
One thought is I could set the table saw to 30* and stand it up, cut through with the blade raised to its max and then finish the cut with a hand saw. Only problem is I don’t have a hand saw and wouldn’t trust myself to cut straight with no hand tool experience.
This will be the base for a plaque I’m making similar to the picture below.
