I've purchased my first band saw, a Craftsman 10" 2-wheeler, and looked for info on correcting for blade drift (after I found out there was such a thing, when I took a closer look at the second pieces I had cut, using the fence, and saw that they were tapered!). However, all I have found seems to apply to 14" and larger saws, which apparently have fences that can be adjusted relative to the table, similar to the adjustments available on T-square fences for the tablesaw, and the methods given for measuring and correcting drift that I found are only applicable to these larger saws.
On this small saw, and possibly most/all of them, the fence (if provided, they don't all seem to include one) is arranged to lock from both sides of the table, so it always squares to the table. The only adjustment I can seem to find for blade drift, then is, possibly, the small amount of play in the bolts that clamp the table to the trunnion (although this may also be limited by the saw slot, so it looks iffy as to whether it's practical to correct on these small saws).
Does anyone know a good method, given this adjustment situation, to determine the error and correct the table/fence combination to the drift? Or, should I just forget about measurements and just try to adjust by "guess and by gosh"?
Or maybe I need to discard the factory fence and make one that's adjustable (not that I would know how to do that successfully)?
Thanks, John
Thanks, John
