homemade plywood
BKHam
Bradley
first pic is just showing off the miter and top that is rabbetted in.
the box sides were resawn 4/4 down to 5/16 and you can see the bookmatch wrap grain.
i've done a few of these and i used to miter the top of the sides and all four sides of the top. i didnt worry too much about movement on a small box. but all those miters were tough to work with. so you see below i did a rabbet instead.
wider view of the one above is on the left. one on the right is curly cherry veneered on 1/4 MDF.
i didnt want to worry about movement at all so i made homemade cherry core with some offcuts from the sides. 7 layers at about 1/16 apiece.
that got me thinking....what else would be cool for homemade ply. so i made these valentines bracelets for my wife and daughter. shop sawn walnut with a little walnut burl on the outside. i had tiny pieces of burl left so this was a cool way to use them. this thing is less than 1/4 inch thick but super strong. ended up buying a 3 inch forstner to make the hole in the middle but 2&3/4 might be the right size.
sepelle with doug fir alternating. i didnt pay attention to the end grain orientation on this....hindsight. but it came out cool.
Those wood bracelets were very popular when I was 16. I made a few for classmates in high school. Didn’t have a lathe, just cut out with coping saw and sanded.
BKHam
BKHam
Bradley
cutting these out was a bigger pain than the pics let on. a 3 inch forstner is not that fun to work with and can easily bind. i ended up having to cope out one of these as well.
MarkE
Administrator
Very cool.
I made a few similar bracelets a while back. Cut them out with different sized hole saws. Got several sizes out of each glued up stack.
BKHam
BKHam
Bradley
Very cool.
the hole saw would prob be better since it doesnt have to remove all the material, just the "saw" kerf.
