WOW, Thanks for all the replys, ideas and compliments!!
I'll try and catch all the questions:
Ray Martin: Yes, they are basically magazine racks (there is a 2" depth inside). The top on one is intended to hold TV remotes, etc, and the bottom is for whatever book the wife is readings plus her crossword puzzles. On this one they are attached with screws (I don't usually use metal fasteners but for the proto, I wanted to be able to adjust them as necessary). The final ones may have one or two depending on where it will be in the room.
Insomniac and C Powell: Feet are something I had not thought of, but I like the idea. I had originally intended to edge frame the bottom to compliment the top edge profile, but after building the carcass, realized that anything I put would be too fragile/narrow with the depth of the door and I was pretty much at max heighth so couldn't add a base. The next ones will have the edge and with the suggestion, I'll also relieve the centers to create feet on the corners. (I'll be raising the floor of the doored compartment and shortening the door to give more roomat teh bottom without increasing overall heighth.
Cpowell: The bottom, drawer compartment bottom and top support and back are all dadoed in this one. If I read you correct, if I use solid wood I will need to run the grain crosswise on these pieces to expand with the sides (sides having the grain running vertical) and just glue the center of each piece in the dado. Is this correct? or is the conventional approach to run the sides grain horizontal and the cross pieces fwd-aft? To go with frame and floating panels will probably mean another prototype but I'll run it past LOML. She'll probably say "Whichever is easiest" which really means "I'd like to have them THIS decade!"
JMauldin: I may try spraying alcohol stain. I was using on-hand supplies for this one but i realize there has to be a better way or better materials than minwax oil stain and their quickdry poly. What are the drawbacks of Ash that you don't like?
As for Christmas, that's no joke!! It took me a full day just to hand-cut the drawer dovetails! (and they really look better in the picture but don't tell anyone!)
Another "lesson learned" (synonym for screw up) was when using Lowe's Arauco plywood, surface it BEFORE cutting the dadoes. I didn't and then realized I would have to take off the top 1/16" on both sides to get past all the mill marks and surface texture defects, which would have made my dadoes 1/8" too wide. Thats why the plywood sections have so many noticeable stain "anomalies". And that was using a pre-stain sealer.
As for wood, SWMBO has already nixed red oak (sorry DaveO or I would have relieved you of most your stock!!) because she thinks it would be too "red', so that probably nixes cherry and birch as well. So, its looking like Ash or soft maple. Will soft maple be hard enough for the top which will see some abuse? At about (my calculations) 20bf per copy, I probably can't afford too exotic a wood for the overall, although a complimentary wood for top and maybe door/drawer is something that may be doable (good idea skeeter).
By the by, the drawer carcass is poplar. Will that need to be changed?
As you can see I am definitely a novice but am having a ball learnin'. Thanks again to all. Hey, is this a great forum or what!!:mrgreen:
and i just realized another "Lesson Learned'. I should have separated all the above into separate posts. Guess I'll never get my count up!!:BangHead:
