Dewalt DW735
Canuck
Does any know what the minimum board length the 735 can handle?
Just investigated that and appears that 12" is the minimum length.
( I had a nice piece of QS oak that was about 11 1\2" long. I just glued a pair of runners to each long edge, ran it through to ultimate thickness I wanted and sawed off the glued runners on the band saw. Worked great!)
creasman
I ran some pieces through mine a couple of days ago that were 10-1/2". You can also use runners as Wayne suggests if you have a shorter piece.
Could the runners be attached using the brown paper bag method to save having to saw them off, loosing stock? Hot glue maybe, or CA if they aren't going to have a stain applied.
jfynyson
Jeremy
I'd suggest using the CA glue + painter's tape trick to affix short pieces to a planer sled or just a flat board longer than the minimum recommended length for this machine. I got great results recently doing this for very thin boards (not short).
Martin Roper
Martin
I've never had that planer, but on the two planers I've had I have run short boards one right after the other without issues.
