"Climb cutting"
Tom Dunn
Tom Dunn
In the latest issue of Fine Woodworking theres a piece on cutting butterflys in checked wood. The author states the he uses "a 3/16th straight bit, working right to left, climb cutting to keep the bit from pullingpast the layout line."
I have no idea what "climb cutting" is?????
Can ya help a guy out?
Cutting with the rotation of the bit. The normal and safest way is against the rotation. A climb cut needs to be made very shallow, removing little wood per pass, because the bit wants to grab the wood and "climb" away from you. A climb cut is often good for cutting against the grain and with woods that chip-out easily. But please be careful, it isn't the safest cut to make:saw:
Ozzie-x
Randy
Climb cutting is a technique where the rotational direction of the cutter or blade tend to pull the tool or wood into the cutter. This is generally considered unsafe and absolutely verboten with some tools and operations, like ripping on a radial arm saw. The cutter or blade can catch the wood and pull the wood into the machine, or in the case of a router, the router can jerk away from you and mess up your workpiece not to mention the safety hazards. This is why you make the cut into the rotational direction of the cutter or blade. There will be times due to required operations, techniques or situations where you have no choice but to climb cut. When you have to climb cut, a good & sharp cutter or blade will help avoid disaster, along with slow controlled feed rate and a firm grip on the wood or tool. Hope this helps.
jeff...
I really don't like to climb cut, standing on a limb with a chainsaw is pretty dangerous.
T
toolferone
Tom, thanks for taking the time to share your article with us. It is real good info!
