This is not a gloat because there was already a post about my Top Tip that is in the current issue of Wood Magazine.
The prize that came today is a Shop Fox bench top mortiser (W1671). The problem, of sorts, is I already have a Delta (14-650) so I am trying to figure out which one to keep. Here are pics of the two units:
Differences and comments:
Both units were made in China, probably the same factory, so fit and finish is about the same- typical Chinese imports. The aluminum finned motors look identical except for the paint and ratings:
Shop Fox 3/4 hp, 7A, Delta 1/2 hp 5A I have never had a problem with the 1/2 hp bogging down.
Shop Fox 3450 rpm, Delta 1725 rpm The Wood Mag speed chart at this link indicates rpm for drilling wood with a brad point bit of typical mortiser sizes should be 1800 rpm or slower for soft wood, 1200 rpm or slower for hard wood. I know mortising bits are closer to augers but close enough for this comparison. Will a bit running at 3450 create too much heat, over-temp the bit and the chisel? Will the 3450 rpm make smaller, easier-to-clear chips? Or will there be no discernible difference?
Fence mechanisms are similar and not great for either.
Counter balance- both have a single gas spring cylinder.
Head travel:
Shop Fox- 9" , Delta- 5" . Total head travel is not much of an issue to me, though I have a riser on the Delta to make room for a cross-slide vise.
Shop Fox rides on dual tubes, Delta rides on a dovetail metal gib. The Delta is harder to move up and down and the gib is a pain to adjust. The Shop Fox moves MUCH more easily and no adjustment is necessary.
Both have a long handle. The Shop Fox handle is a bit funky and has a lot of slop, but I can easily modify it to fix this.
So what do you guys think? Anyone had much experience with a Shop Fox? Most mortisers run at 1725 rpm. What do you guys think about the Shop Fox 3450 rpm motor? Will it cause overheating of the bit or chisel? Is that a big issue? If it isn't, then the Shop Fox stays and the Delta goes.
Head travel:
