I've basically finished what I considered the high priority changes for the Photo Gallery. They consisted of several areas.
We need new FAQs for the new way things work and look. Please volunteer to write new ones or modify existing ones.
A lot of suggestions were made about posting pictures and the Photo Gallery. Almost everyone was an excellent suggestion. But with limited time for now, I chose the ones that I thought had the highest priority. Many of these will be look at again when I have more time. But the bottom line, is that with the set of changes I just made I broken the rule about changing PhotoPost code and be more willing to make further changes as time and necessity dictate.
So please feel free to make further suggestions and/or problem reports via the "Help Desk"
The Menu under a full size photo has been changed from icons to to the traditional type of menu and the wording has been changed to help people understand what they do. ( I hope)
The links area under the menu has been changed so that all links are visible and a better description of how to use them has been provided. There are now 2 different sets of link that will Display.
Direct links:
These are the links that best work with the Insert Image
function of the post editor. These Direct links have had a minor change, the http:// has been removed so that you don't have to delete the http:// that shows up, you just copy and paste in to the insert image function dialog of the post editor.
BBCode links:
These type of links are best for those people that would rather NOT use the insert image function, but rather copy and paste directly into their posts where they want the picture
To save space, only one set of these links will show at any one time. There is a new menu item "Switch Link Type" that will allow you to toggle between these two views.
Which link set is the default? There is a new user option that allows you to set your preference. Right now and for new users it is set for direct links. You may change it at your discretion.
Please try these new areas and ask questions. Report any problems that you are having. If any of the wording can be improved also post it here.Which link set is the default? There is a new user option that allows you to set your preference. Right now and for new users it is set for direct links. You may change it at your discretion.
