Cedar strips
JEM
Matt - JEM Watercraft
I need a whole bunch (250+) of cedar strips cut to 1/8" x 3/4" from mostly clear lumber. Desire strips to be around 6-8' long. Consistent and square is a requirment.
I'm thinking about buying a band saw and doing it myself but I'm not sure what a local shop might charge me. If the price is right, then I'll pay someone else do it. I'd like to pick up so I prefer a shop within about 1.5 hours of Greensboro.
I'm going to start another thread asking how much I'd need to spend on a good band saw to do the job. http://www.ncwoodworker.net/forums/showthread.php?p=85567#post85567
striker
Stephen
Anchor Hardwoods in Wilmington used to supply quite a bit of EWC strips to the canoe building market. That was a few years back under a different owner. It may be worth a phone call to check with them and see if they continue to supply it. He's listed under the NC lumber suppliers.
Stephen
Joe Scharle
Here's a jig I use to cut long strips & splines. Might be what you need.
jeff...
User not found
Clear ERC might be hard to find, I have yet to see a cedar without any limbs.
JEM
it's for a kayak but not a traditional woodstripper. I'm making a plug for a fiberglass mold.
Alan in Little Washington
Alan Schaffter
I'm a little late in this thread, but if you are looking for good straight-grained lumber for a plug you need to get clear, flatsawn Western Red Cedar, NOT Eastern Red Cedar which has lots of knots and not straight-grained, or some Sitka Spruce. WRC machines nicely and should be easy to shape and fair.
It would be a lot easier to cut the strips on a tablesaw than a bandsaw. First plane the lumber to 3/4", then, rip-joint-rip-joint-rip, etc. your 1/8" strips. To ensure smooth faces and consistent thickness you can rip the strips slightly thicker than 1/8" and make a final pass through a planer.
That is how I made the strips for my last cedar strip canoe.
Depending on your frame, you might want to rip the strips a little thicker than 1/8" to have a stronger plug.
JEM
Any chance you'd be looking to make a couple bucks doing this for me?
Kyle
Kyle Edwards
that many strips of that length on a table or a bandsaw is nuts.. an accident in the making.
order some 10-12 foot clear WESTERN RED CEDAR or REDWOOD or YELLOW CEDAR and have Jeff or a local sawyer bandsaw it for you..
it will be almost impossible to get lengths of clear usable cedar from local stock..
jeff...
User not found
Slick one there Kyle "have Jeff or a local sawyer bandsaw it for you.." Sorry not going to try - no can do, 3/4 x 1/8 strips on the band mill :slap:
Kyle
Kyle Edwards
shoot I have bandsawn LOTS of strips of clean cedar for strip canoes..
1- cut them as regular 3/4-4/4 boards or have him plane the boards to 3/4 thick
2- shave off 1/2 to 1/4 strips off of several of those boards. Set boards vertical (4-5 or more) on the mill
3- 15 minutes later you have a BOATLOAD of strips to finish plane/drum sand.
1-2-3 :)
jeff...
User not found
1-2-3 :)
Sounds like you got it all figured out - go for it...
JohnsonMBrandon
Brandon Johnson
Kyle if you do ever have time coming up let me know I may interested as well. I know you are a busy man though....and I am too.
- Brandon
jeff...
User not found
My first thoughts were if I gave it a try I would make a bunch of junk. But after thinking about it a little, I could see standing a stack of 3/4 boards on edge and clamping them together with a few big c-clamps, clamp the stack down and swipping off 1/4 strips, then runing them through the planer to bring them down to 1/8", I still think at 1/8" thickness some would break, cedar is some pretty brittle wood when dry.
Only three problems I see:
#1 my planer will not go to 1/8, so I would need to rig up a jig. No real issue here, just takes a little more time.
#2 My mill head wont cut any lower than an 1" off the bed, so 1" of each board would be lost.
#3 Like you I really don't have the time, right now.
Kyle, got your email - but it appears I cant send a reply because of a server problem. Please excuse my 1/2 baked attempt at humor. Now that I re-read what I wrote it wasn't funny at all :roll:
Alan Schaffter
Boy you guys are making this hard!!!
When I made my cedar stripper canoe, I started with 18'-20' long flatsawn WRC boards, already planed to 3/4". I ripped them into 1/4" X 3/4" strips with a SHOPSMITH no less!!!! You all know how small the table is on a Shopsmith! I separated the halves of an extension ladder and rigged the halves as infeed and outfeed tables.
I had to do a a bit more sanding after the glue-up since I didn't have a planer or jointer, but fairing the hull required a lot of machine (belt and random orbit) and hand (block and spline) sanding anyway. The WRC was soft so sanded easily. That is why I recommend 1/4" vice 1/8" thick strips for the plug.
To make a plug, you'll be doing a lot of fairing and sanding- you'll want it as perfect as possible, to make the mold, especially if you plan to go into production making multiple kayaks. I suspect you'll use a lot of light weight Bondo also. You gotta get that plug perfect. You don't already have a finished fiberglass or plastic kayak that you can spray with mold release and pull a mold from? That sure would be the easiest method. You can always turn the first hull into another plug if it has imperfections. Do you have a chopper gun, or will you be laying up the mold and subsequent kayak hulls by hand?
If I had the material (nearly clear WRC) and you were closer (I'm 1hr+45min east of Raleigh) I'd consider taking the job.
