Today, I bought a 2" foam, hook & loop sanding pad at Klingpors. I was using it in a drill to sand the inside of a bowl and, apparently, got carried away. The pad got hot enough to melt the tar-like substance that holds the pad on the foam. It slid about 1/3 of the way off-center. I tried to slide it back before it cooled but had no luck. Now that it is cooled, it tears the foam if I try to remove it. Even if I was able to get it off without tearing the foam, what type glue would be used to repair it. I imagine I just tossed $8.95 out the window to be followed by another $8.95 for another one. Oh well, I was "discount qualified" so I guess I only tossed $8.05 (small consolation). Ideas anyone?
