Box construction materials
AmishWarlord
Mitch
When building an item like a gun case is it accessible to use materials like MDF or plywood for the inset that will be covered by velvet or for quality should this also be made of hard wood?
On one hand I can see that it's glued in, cover over, never to be seen.
On the other hand if you do that then why not use plywood cover in veneer instead of solid wood.
Thinking about it I guess if it's a commission job and the client wants to go as cheap as possible but still have the look of a finely made item I guess veneers and MDF are in order. As for an item for myself I'd want to know the item is solid wood.
Does MDF off gas like it used to? I would be careful about that in a confined space with fine steel. Check it out before you end up with some rusty junk.
bobby g
Bob
AW,
I would think that using a good quality plywood would be a plus since it would offer strength and stability at a reduced weight. Proper application of a veneer to both sides would take care of any appearance issues.
bobby g
If you're charging appropriately for your time and labor, putting veneer on plywood will probably end up costing as much, if not more, than using real wood in the first place. Just a thought.
AmishWarlord
Mitch
That would suck! Someone should tell this guy. He'd making a case for two Civil War era pistols.
Aqueous formaldehyde is corrosive to carbon steel but is not corrosive in the vapour phase.
So it seems that as long as there is some way for the vapor to escape it won't rust the steel.
AmishWarlord
Mitch
I'd really like to be able to build cases like this one.
I was just thinking about what kind of wood to use under that blue velvet. Since it's hidden any old ply would work. I guess it's more artisan to make it out of the same wood the case is.
Randall Kepley
Randall
Using MDF will be fine. I would suggest if your worried about it, seal it with a good vinyl sealer and you will definatly have no worries. R.K.
AmishWarlord
Mitch
Since this is a hobby artisan project for myself I want it to be high quality. So I'll use the same wood for the nesting tray as the box sides. It's hidden but I know it's there.
Reminds me of a belt I made for this guy one time. It had forest animals on it. I asked him what color stain he'd like on the leather. He said black. I said that if I stain it black then you wouldn't be able to see the animals. He said, "Yes but I know they are there, like animals in the night". LOL black it is.
So know the good wood is under there.
Actually maybe I'll use less velvet. Now that I think about it I wonder if people fill up the box with velvet to hide more of the cheap filler? Maybe I should do my boxes where you's see 80% of the wood on the inside and just have velvet where the wood would touch the metal.
Berta
Berta
Now, I like the idea of using less velvet to showcase the wood. I think that is the perfect solution!
Berta
"Actually maybe I'll use less velvet. Now that I think about it I wonder if people fill up the box with velvet to hide more of the cheap filler? Maybe I should do my boxes where you's see 80% of the wood on the inside and just have velvet where the wood would touch the metal. "
