Wow, prices have gone up!!. I got mine at Lowes with the edge guide, vacuum attachments and the guide bushings (just 3) for $232 about a year and a half ago. It was on special, tho, so that price looks good for today.
Good router with one caveat:
The on-off rocker switch is not sealed, and the motor running pulls in fine sawdust through the switch, resulting in it not turning on, or underpowered, when the switch loads up. I have had to remove the switch and blow it out with canned air twice already, and I use the router only occasionally. This may be fixed on the newer ones, and I do not have a dedicated router table (just a makeshift top made from a computer desk surface), so this may not be a problem if you have good vacuum pickup on your table. Plunge mechanism is a bit stiff, also.
You may want to look at one in a store first, because this will probably be a lot heavier than the Skil, and more top heavy with the plunge base. Just so you are aware.
