I have a somewhat small stack of rough sawn material which I dearly want to protect. Most of it is oak, SYP, some maple, poplar and mahogany. All of it is lying around the shop in various stacks, except a bit of rough sawn oak, which is stacked outside on stickers. I am about to finish a shed extension to my barn, which will have a lumber rack to permanently store all of this and get it out of the shop. My question is should I spray some type of insecticide on the wood, while stored outside in the rack to ward off bugs; i.e. beetles and borers?
I've read (ad nauseum) about heat treatment, kiln or other drying processes and will definitely do this on an "as used" basis. I have the heater, an insulated box, thermometers, et al for this. But prior to using, is there a boric acid mixture or other such solution I can put in a pump spray device and thoroughly coat the material with? I've seen advice for controlling ants and such, but the quantity seems too small for what I had in mind. And neither am I sure of what the appropriate mix is. Thanks in advance for your help.
Ciao ... Dorm
Ciao ... Dorm
