I use a trimaster, and I've had the woodmaster in the past. 1" for both of them 1/3 pattern. I think they do a great job resawing. I'm fortunate in that I have a bandsaw that can tension them enough that drift or bearing behavior is never a problem. I tension them to 30,000 lbs (checked with a Starrett tension gauge) and I really don't even need the guides; it just cuts as straight and fast as I push through it. Biggest resaw I've done is around 13" wide, but I can go up to 17". I can pull 1/32" slices all day; I also have the Laguna fence so I can adjust repeatably for the thickness and I don't have to keep jointing the face because I have the fence behind the wood. Much better yield that way.
K
Hello Kevin
Good to hear you jump in on this one. As a TM user I'm glad to hear you've had good luck with yours. Its funny.. I have to take a step back and "re evaluate" my earlier blade critique.
Yesterday I took a ride down to Scott Smith's wood wonderland. After lunch, we did the nickel tour or maybe I should say the dollar tour. If you like wood you need a towel to dry your eyes. Yes I do love 1/4 sawn wood.
To the point of your message. I love the TM and I have 2 RSKs from Laguna. I favored the TM for the high risk cuts. Yesterday debunked my position.
Scott put some oak on his veneer cutter(16" capability) and produced flawless 1/16" sheets from a board. He uses the Laguna RSK. If it didn't outperform the TM it was clearly its equal. Here's the catch that's worth the price of admission:
You can re-sharpen the Laguna several times to extend the life. In our discussion we laughed at the fact that his and my Laguna blades cut better after the first resharpen than the original blade on its first cut. This was something pronounced enough for 2 guys unknown to each other seeing the same thing.
The Laguna RSK
- you can resharpen 3-4 times
- slightly thinner kerf yields more sheets per board
- the Laguna is cheaper than the Lenox by a small amount
On blade tension:
From a long phone discussion with the guys from Lenox I was told not to go crazy with tension on the TM. Their concern was not the blade but the tires and wheels on my bandsaw. With a 20" wheel they told me to get it snug and try a couple runs. If it doesn't wander leave it be. I guess I use a looser tension setting than I did years ago and it seems to be working well enough.
Scott Smith's service options:
If you have a "precious piece of wood" to be re-sawn, contact Scott. When I cut the lid below from the 8/4 slab, I was tight. I would have gladly paid him a fee to lay the board flat and run his horizontal blade thru this rendering a flat face then cutting to thickness in 2 passes. I spent hours on this slab before I cut it down.
Still want to get up with you K when the day time job allows.
Dan
