Bandsaw Help
Flute Maker
I have an older delta/Rockwell bandsaw I have used some in the past …just whenever I needed it which wasnt a lot. It has worked very good in the past. Hasn’t been abused !
Ive changed the blade maybe twice. I need to again. I took the old one off and put the new one on but the new blade won’t track and stay on.
I have little experience with troubleshooting the ins and outs of what’s wrong.. Where’s the best source online or who can point me in the right direction as to what to look for setting up the new blade. I didn’t have a lot of trouble before. Thanks in advance!
If I turn it manually it stays on but powered up the blade comes off.
Sounds like the tires need replacing. I just did that on my porta band big difference, big improvement.
I get them from Amazon because of my location others may chime in with better recommendations to local outlets. I would get the polyurethane tires they work well.
bob vaughan
Bob Vaughan
Glued on and properly crowned neoprene rubber tires will last for decades. Poly tires will last for several years before the blade tension stretches them loose. Its your time and money and choice.
You didn’t mention it but does this saw have a riser block?
Sometimes they can easily get knocked out of alignment and that can cause the blade to track off center.
rcarmac
Board of Directors, Treasurer
Robert
How do you know when the tires need to be replaced.
bob vaughan
Bob Vaughan
Like they say, no pictures, didn't happen.
A really bad and worn tire
same tire with a new crown.
a couple of worn out tires that need re-crowning
Another Delta poly tire, newly crowned on the left
And below is a study I did in 2006 on those hateful orange poly tires. It turned out that modifying the tire to fit the groove went a long way in restoring a crown.
Here's a poly tire compared to a rubber one. The rubber will grip the wheel much tighter. That said, I still glue on all my tires when I'm doing a Delta 14.
Tire thickness difference.
..this post was probably TMI
bob vaughan
Bob Vaughan
Over the decades, I've bought many a Delta 14 for very short money because the sellers wouldn't address the tire issue.
Linc H
Linc
Bob, Not TMI, really learned something here on crowning. Thank you for sharing!!!
