So, as a full disclosure, I am generally "safe" around power tools but was using my Rikon 10-345 18" BS yesterday to round up a bowl blank in a "not quite safe" way....the surface of the blank against the table had been partially flattened for stability...but obviously not enough stability. While I was trying to freehand round out the blank, the blade got a bad bind,rocked the blank up and jammed the blade to a stop. I powered down quickly, unplugged, easily unwedged the blank and inspected the blade and wheels/tires, table, etc. The "only" problem I could find was a bent 5/8 Timberwolf blade...so much so that it rubbed the saw housing, and table with each revolution and was way out of alignment with the guides. Took off the blade and laid it on the flat floor and noted the "warped" configuration with a 2 foot section up off the floor about an inch an a half...Tried the straighten out some obvious bends with gentle counter bending....Put the blade back on the saw and couldn't get it to track on the wheels. I centered the blade on both upper and lower tires and rotated the upper wheel by hand while adjusting the tracking knob...no improvement.:BangHead:
Then replaced the 5/8 with an old 3/8 blade...reset the tension and guides and made cuts without problems.
Question...is the 5/8 blade toast? It is fairly new and not cheap, can it be repaired? Or have I missed something which will make me shorten my sentence in safety jail?:saw:
