Got the top glued up and sanded back flat (well relitavly flat) but it needs a little something.
Heres the top
Heres the top setting on the entertainment center
It seams like the top needs a profile routed into the edges but what would work. I routed a 1/4 in roundover beaded profile into the base and the drawer. I have cut and routed some strips with an 1/8 inch beaded roundover profile that will be attached to the sides to give a little more detail and give a frame and panel look.
As far as attaching the top. The plans called for several oversize screw holes drilled and counterbored into the ply that will support the top (oversize holes to allow for expansion of the panel). I have predrilled all the holes but I was wandering if it would be better to use figure 8 clips at the corners and a couple of screws near the center to help hold the top flat.
Theres been alot of goofs during this project and so far I have been able to recover, but goofs at this point will get tougher to recover from or hide. Funny part is this has taken me so long that the case, frames, and drawer front are now darker than the freshly milled cherry top and the trim pieces for the sides are. Now how did that happen :dontknow: I guess I'll have to set them in the sun some this week to try and catch up.
Heres the top
