Aluminum Foil and Rust
After last weeks monsoon, my jointer had a faint hint of rust on the beds. Remembering that recently I had seen a tip to use aluminum foil to remove rust, I tried it- It Worked! Just wad up the aluminum foil and use as a scrubber on the rust. Cleans as well a steel wool. After cleaning, rub the top with some waxed paper to make it SLICK. Be sure to buy your own foil and waxed paper.
alleng
allen
Aluminum foil is also a good way to clean a grill surface. Works just as good as a wire brush!!:eusa_danc
