I will post pictures tonight but I almost lost it all. I was working in the shop (my garage) and smelled something burning. I turned off the lathe and dust collector and saw nothing. So back to work I went. A minute later I smelled smoke stronger. I turned in time to see smoke pouring out the duct collector motor. I was able to reach the plug before flames erupted.
When the pulled the cover of the switch housing I found some of the wires and both capacitors were a melted mess. My dust collector [STRIKE]was[/STRIKE] is Delta 50-760. It is about 10 months old with less then 1 hour of actual run time. It is under warrante but not sure how long it will take to get it replaced/ fixed.
I guess I was luck that the dust collector is in my shop and not in a separate room. I would hate to find out what would have happened if I did not pull the plug.
