I'd like some good advice on bandsaw blades. I recently acquired a Grizzly 16" G1073 saw, which came with a 1/2" blade. It takes 113" blades from 1/4" to 1". I assume that, like most blades that come with saws, the blade it came with is not a great blade, although it has been useful for set-up etc.
I'd like to buy a few blades to set myself up for cuts ranging from curved cuts in relatively thin stock such as 3/4" pine or plywood. For this, I was considering buying a 1/4" blade, and a replacement 1/2" blade with a somewhat higher tpi. I would also like to be able to cut larger stock and potentially do a little resawing. So, I was considering a 3/4" or 1" blade, with 2 - 3 tpi.
My challenge to you:
Tell me how I should spend $100 or so on a few blades. Please be as specific as you can (rake, hook, skip, tpi, and definitely source/vendor). I've done some reading and on-line shopping and came away overwhelmed and a little baffled.
Thanks,
Ted
Thanks,
Ted
