OK, so I got the Bosch jigsaw so many folks recommended (photos and a proper gloat forthcoming). I have been doing a few things with it and I am quite impressed so far. I used the circle jig to cut a bowl blank out of some dry 8/4 spalted maple. I ripped oddball shaped green log sections to remove "points" from splitting wedges. I used a long blade and had good results all the way to 4" thick. I did break one blade and I managed to get sparks from the guides a few times.
Anyway, a couple of questions about adjusting speeds (yes plural)...
The Bosch has a speed control away from where your hands are when cutting. You just turn it off an on when you cut and the speed control is a separate control that you pretty much need to set in advance. I have only been cutting wood and leaving it wide open, even when cutting thick wood; I just slowed my cutting speed. Is there a good reason to slow it on wood?
The other speed adjustment is the orbital speed. The manual mentioned slowing or stopping it for hard materials, but I also backed it off a little with the really long blades in thick wood. Any good rules of thumb or particular situations to adjust it? I never had a jigsaw with this adjustment before.
