I'm making the Bright Idea Candle Holder featured in Wood Magazine (July '09; issue 191) and have run into a snag.
The parts on this project are small. One part in particular is 3/8" thick, 4.5" in length and 1.5" wide. The directions advise to cut a 1/8" rabbet - 1" deep into the end of this piece.
I haven't been able to find a rabbet bit that is 1".
I tried to cut the piece using a dado blade set on my table saw and get OK results but the dado blade leaves ridges in the wood (which I can sand out with some degree of success). I tried using a 3/4" straight bit with my miter gauge on the router table but the depth is not even for some reason when I make the second pass.
My question is this: Is there such thing as a 1" rabbet bit? If so, where can I find one?
If there isn't a 1" rabbet bit - how would you make this cut?
I could use any advice you have to offer. I don't use my router table much and am perplexed at this time.
Thanks,
Thanks,
