relief
PIC 23 - Step 5i
Closeup of a screw in the Horizontal Stabilizer
MT native
Media item
Oct 28, 2008
carving
drill
foredom
homemade
jig
press
relief
Comments: 0
Album: Homemade Relief Carving Jig
PIC 22 - Step 5i
Pre-drill for the screws that will secure the Guides horizontally
MT native
Media item
Oct 28, 2008
carving
drill
foredom
homemade
jig
press
relief
Comments: 0
PIC 21 - Step 5h
Trim the corner of one of the Stabilizers to add clearance for the Depth Adjustment Rod
MT native
Media item
Oct 28, 2008
carving
drill
foredom
homemade
jig
press
relief
Comments: 0
PIC 20 - Step 5g
Cut two (2) pieces for the Horizontal Stabilizers 1.5in x 1.5in and drill min 3/8in dia holes in centers for the Guides
MT native
Media item
Oct 28, 2008
carving
drill
foredom
homemade
jig
press
relief
Comments: 0
PIC 19 - Step 5d
Z-axis Support dry fit - four bolts in center for attachment to the Floor Flange on the Frame
MT native
Media item
Oct 28, 2008
carving
drill
foredom
homemade
jig
press
relief
Comments: 0
PIC 18 - Step 5b
Square the back (‘spine’) and ends of Z-axis Support before drilling pocket-holes - end view
MT native
Media item
Oct 28, 2008
carving
drill
foredom
homemade
jig
press
relief
Comments: 0
PIC 17 - Step 5b
Square the back and ends of Z-axis Support before drilling pocket-holes - side view
MT native
Media item
Oct 28, 2008
carving
drill
foredom
homemade
jig
press
relief
Comments: 0
PIC 16 - Step 4b
Closeup of Foredom Hanger - FOLLOWUP - DO NOT USE ANYTHING ON HANGERS!!!! MESSY, STICKY, GOOEY YUCK!
MT native
Media item
Oct 28, 2008
carving
drill
foredom
homemade
jig
press
relief
Comments: 0
PIC 15 - Step 4a
Place the Foredom Handpiece in the Hangers and check to make sure there is clearance between the end of the carriage bolt and the Handpiece
MT native
Media item
Oct 28, 2008
carving
drill
foredom
homemade
jig
press
relief
Comments: 0
PIC 14 - Step 3e
Dry Fit the Handle(s) into the Middle Section of the Carriage. Trim off the excess tubing
MT native
Media item
Oct 28, 2008
carving
drill
foredom
homemade
jig
press
relief
Comments: 0
PIC 13 - Step 3d
Insert the 4in piece into 1/4in I.D. Vinyl Tubing and bend in a vise to make the Locking Handle
MT native
Media item
Oct 28, 2008
carving
drill
foredom
homemade
jig
press
relief
Comments: 0
PIC 12 - Step 3c
Cut a 4in piece from 1/4in-20 x 36in long Threaded Rod. I used a Hack Saw
MT native
Media item
Oct 28, 2008
carving
drill
foredom
homemade
jig
press
relief
Comments: 0
PIC 11 - Step 3b
Screw a flat washer over Coupling Nut to keep the Nut from working out when under locking pressure
MT native
Media item
Oct 28, 2008
carving
drill
foredom
homemade
jig
press
relief
Comments: 0
PIC 9 - Step 2f
Assemble the Carriage - Add four (4) Flat Washers, the same thickness as Bushing flanges, between the sections so the Carriage will be square and level
MT native
Media item
Oct 28, 2008
carving
drill
foredom
homemade
jig
press
relief
Comments: 0
PIC 8 - Step 2e
Drill holes in the side(s) (Middle Section only) for the Locking Handle Coupling Nut(s)
MT native
Media item
Oct 28, 2008
carving
drill
foredom
homemade
jig
press
relief
Comments: 0
PIC 7 - Step 2d
Re-drill (Middle Section only) to allow for O.D. of the Flanged Bushings and the Coupling Nut
MT native
Media item
Oct 28, 2008
carving
drill
foredom
homemade
jig
press
relief
Comments: 0
PIC 6 - Step 2b
Four (4) holes for clamping, two (2) for the Guides and one (1) for the Depth Adjustment Rod
MT native
Media item
Oct 28, 2008
carving
drill
foredom
homemade
jig
press
relief
Comments: 0
PIC 10 - Step 3a
Insert the Coupling Nut as perpendicular as possible by using a bolt as a visual aid
MT native
Media item
Oct 28, 2008
carving
drill
foredom
homemade
jig
press
relief
Comments: 0
PIC 5 - Step 2a
BEFORE YOU DRILL Use masking tape to bind the pieces together to ensure hole alignment
MT native
Media item
Oct 28, 2008
carving
drill
foredom
homemade
jig
press
relief
Comments: 0
PIC 4 - Step 1i
Table bolted to frame with rubber Bumpers for feet and shim to prevent MDF flexing
MT native
Media item
Oct 28, 2008
carving
drill
foredom
homemade
jig
press
relief
Comments: 0
Prev
First
Prev
5 of 6
Veritas Plows Plane -$195.00
Started by dancam
Today at 9:41 AM
WTB: Walker Turner 1100 Drill Press Depth Stop Parts
Today at 7:50 AM
Many issues of Fine Woodworking
Started by buckaroo
Yesterday at 2:29 PM
Free Magazines
Started by chgorugbyref
Sunday at 11:15 AM
Delta Unisaw for sale
Started by Ray Morgan
Saturday at 11:21 AM
