Work In Progress: Walnut Trestle Table
BKHam
Bradley
i bought most of the wood for this project from a guy in hillsborough who sells walnut slabs, he usually has a CL post up. Its not a commercial operation so the boards reflect this, a little bit knotty. when i bought these maybe 8 years ago, i was just happy to find cheap walnut. however, my eye for good lumber wasn't very developed. I've had quite a bit of waste to get to this point.
the top comes from two slabs, each containing the pith. I've cut the center out of both. I got really lucky with the center glue up, its not super prominent. the cathedral looks almost like it goes together. pleased with how this part came out.
the support structure is connected to the top with a sliding dovetail. I routed in from one side and will fill that once everything is glued up.
that piece is attached the legs by a shouldered half lap. that is connected to the feet by big half inch double tenons.
i still need a piece that connects the legs and will receive the trestle. some final comments:
-the legs and feet are 4x4s and a real pain to deal with....table saw won't cut thru them, tenon jig can't handle that size either, I don't have a chop saw (which would be nearly maxed out as well unless you had a 12 inch)
>this was a mistake that i could have avoided just planing the material to just under 3.5 but i wanted to leave the thickness
-i had to buy a little extra walnut for a couple pieces due to all the waste - this was kiln dried.
>kiln dried is brown, thats about all i can say about it. you get none of the golds, reds, deep chocolate, even greens you see in air dried
-using 8/4 for the top has caused me to beef up all the lower parts to try and make it more stable - another choice i could have avoided
-the leg assembly actually came out square!
> with mortise and tenons at bottom, half laps at the top and the connecting pieces being two different lengths, i had to work off center lines, a ton of room to mess this up
- i will be spraying with general finishes outdoor 450 satin water based poly
-in addition to the trestle, there will be stainless steel footrests going from leg to leg
Trey1984
Trey
Really like the top. Looks great! Other than visual could you tell a difference in working with air dried and kiln dried tool wise?
BKHam
BKHam
Bradley
I haven't used hand tools on the kiln yet. Those pieces are all on the base. Top is all air dried. I will keep this question in mind when I start to.prep surfaces.
Wilsoncb
Williemakeit
It looks like you are doing great. Based on the issues you listed, I would have lost patience and compromised the quality of work... and regretted it. If you are like me, you are your own worse critic and know every detail that didn't live up to your expectations. You should really feel good that you were able to use some lower grade walnut and make something that looks that good. I admire your persistence to make the best from the material you have. I would not have known the material wasn't the best based on the pictures/results. I have a project I really want to make out of walnut, but given current prices, it's just not going to happen.
drw
Donn
Very beautifully designed and crafted! The heart is a classy touch, both functional and expressive!
