work in progress, 1/6th 1890's navy steam launch built to navy plans
T
tghsmith
tghs
and just like that you start seeing her lines...
drw
Donn
Very, very impressive. I have built ships from kits, but nothing on the level you are doing! Thanks for posting!
T
tghsmith
tghs
started the white cedar hull planking,, so much easier than white oak,, needs only a hot water soak and a little hot iron work and the curves are set,, things should speed up a bit.. have to start laying out the cradle for when the hull comes off the board!!!
T
tghsmith
tghs
getting to the less twisty planks and starting the spiling(naut. term for shaping) of planks for proper fit.. , the Lee Valley 1/3 scale planes are working great for this shorter plane taking deeper cuts to get things roughed dowm,, long plane set fine to even the final line..
T
tghsmith
tghs
shop assistant slim trying to convince me he actually does work,, still planking away,, starting to shape things from the keel down (or up, this is confusing)
T
tghsmith
tghs
so the last planks could be clamped (no long reach small C-clamps) it was declared "off the building board" day .. a friend, two heat guns had the hot glue giving up it's grip on things in a few minutes, set some metal items in place to get the look of things
jpet86
Your work is amazing. The attention to detail. And your going to have working steam, truly amazing.
T
tghsmith
tghs
thanks all,, planking complete,, seams calks with epoxy paste,, lots of sanding,, given a good heavy coat of primer that will be mostly all sanded off.. coated the inside with epoxy resin with milled fibers added along with tinting to match the navy spec'ed lead gray color.. everything gets to set and cure for the weekend..
JNCarr
This has been a most amazing build, showing great skill, patience and a great sense of humor.
Slim really helps put the actual size of the boat in perspective.
Thanks for taking the time to post all of this wonderful work.
T
tghsmith
tghs
Slim is back on quality control as the leveling of the frames inside has started,, this need to be precise as I plan to use the line where the decking meets the waterway as the point to make the deck removable.. exacto spokeshave is useless (LV scale spokeshave is in transit) the dremel right angle head is great for roughing things out then its homemade flex sander and sanding blocks..
Martin Roper
Martin
When I was on the USS Theodore Roosevelt in 1988, we visited the French port of Toulon. I was in an antique shop that had a number of vintage nautical items. One thing that caught my eye was a drawing of the bowsprit and figurehead portion of the bow for an 18th century French warship. It was done using the same artistic technique as this:
My guess was that it wasn't a shipwright's plan, but a rendering in a collection of drawings to be presented to the admiralty for approval for construction. There was some added notation in French in the margins in impossibly elegant handwriting. Imagine something like this but much more detailed and ornate as above:
Including the border it was about 45"x30" and priced at about $175 which seemed like a lot of money to me at the time. I pondered for a while and even did another lap around the store looking at other items before returning to it, but ultimately walked out without it.
I don't have too many regrets about things I didn't buy, but that is one of them.
T
tghsmith
tghs
I almost drove back 90 miles for a belt buckle I passed on in AZ.. (still wish I had gone back) A woodsmith/boatbuilder selected me a great piece of hackmatack for the project,, re-saw fence on the bandsaw to slice it up,, put on a very narrow blade to rough out the knees and corners.. (faster and cleaner than the scroll saw) clamp boards have been formed and set in place,, marked out for knees, timbers and beams,, wood for the bilge boards have been prepped,, the LV scale spokeshave arrived,, looks and works great.. used some number stamps as small branding irons to mark select frame numbers on the keel...
T
tghsmith
tghs
mounting up brass fittings and making mountings,, engine mounting beams installed, rudder fittings installed, cut-water installed,, most of the floor beams installed,, its been a good week.. told slim all he had to do over the weekend was watch the epoxy cure..
T
tghsmith
tghs
more progress,, frames leveled for mounting the boiler support keelsons,, blocks added where pipes for the keel mounted condenser will pass through,, clamp boards and main cross beams mounted,, the clamp boards removed any gunnel flex the hull had.. I may be on the lookout for a long piece of air dried cherry 1 x 2 x 36 to bend and form the cap molding ..
Pat M
Belg
Fantastic work, did you make the steam engine components? I've build models over the years for my MRR but nothing this complex.
creasman
Would love to see some of the process you follow when casting and milling the parts.
