Short version: What strategies do you use to turn pieces that have punky/soft wood section? Is this junk wood not worth turning?
Longer version:
A friend provided the lowest section of a maple trunk from his yard tree. This is turning fodder for me to turn larger pieces. I am relatively new to turning (max diameter of 6-7" so far) and several of these blanks are 11-14" in diameter.
The first piece I tried to rough out has nice color variation in it, with some mild spalting. There is also a soft/punky section that is 3-4" wide at the rim that continues to the center of the piece. This portion does not cut well with either a bowl gouge or scraper. Sanding this area does nothing at all (as I would guess most of you know)
Can this soft wood be stabilized with CA glue or something like MinWax wood stabilizer? Is this junk wood not worth turning? What strategies do you use?
Thanks
Henry
(cross posted at WoodCentral)
Longer version:
Thanks
Henry
