Hello All;
Some years ago I read an article in Wood magazine about how to wet sand between coats of any brush on finish. I've used the method quite sucessfully a few times, and I wonder if anyone else has used it. Also, I have a question about the final step. At the time, the magazine stated that this process was borrowed from auto body shop techniques.
Steps are:
1) after 1st coat is dry, put water with "Dawn" dishwashing liquid in shallow container, and use 500 grit wet/dry sandpaper on sanding block in rotary motion. Rinse off with damp sponge with clean water. Dry off with clean rag. The purpose of the Dawn is to cut down on the friction between the wet/dry sandpaper and the work piece.
2) Do subsequent coats the same way as #1
3) Final coat, same process, but start with 1500 grit and work up to 2000 grit wet/dry.
4) final polish - use Turtle wax or similar car wax, and buff with cotton pad either by hand or with power buffer.
I think this works great for a brush on finish, such as polyurethane. I've also used it on water based varnish.
My question is, though, I tried the final step with the Turtle wax a couple of times, and I wonder if there might be another wax that might be better to use.
Any thoughts? Has anyone else tried this method? It seems to me that the article is in the archives of the Wood magazine web page, or at least used to be.
Thanks,
Steps are:
Thanks,
