Time for a New Set of Tires
Today, I installed a new set of urethane tires on my bandsaw. I have found that there are two choices, either blue (Carter), or orange (all the rest.) Prices vary greatly, with Hartville having a SET of orange for $24.90. Woodcraft has the blue ones for $23.09 EACH. Klingspor's price is similar to Woodcrafts. But I had this set for some time, so I don't remember what I paid for them. Installation was straight forward. Remove wheels from saw, and remove old tires, which had been glued on. Using a rag and some laquaer thinner (outdoors), old glue came off very well. I took new tires and put them in a pan of boiling water (you gotta cook them first) to make them more pliable. After stretching each on the wheel, I took a screwdriver and put it between tire and wheel. I ran this around the wheel a couple times to even out tire. Checked the bearings while I had the wheels off, no noise, or grinding. I just can't figure out why Delta would use SHIELDED bearing on a saw that produces such fine dust.
Ray Martin
Ray
Bruce,
You said you had the old tires for some time... just how much mileage were you able to get out of them? I was just wondering whether you find one type better than another.
sapwood
Roger
Thanks for the blow by blow, Bruce.
I'm pretty sure mine need replacing and your technique will prove useful :icon_thum
Roger
Trent Mason
Trent Mason
Thanks for sharing Bruce. I think mine still have a few years left in them, but I will remember this thread when the time comes. :icon_thum
Glennbear
Glenn
Thanks for the blow by blow Bruce. I think shielded bearings are used BECAUSE of the fine dust and to keep factory lubricant contained to prevent contamination of areas that contact project wood. :wsmile:
Sealed bearing would be a better choice. Delta uses sealed bearings on the bottom wheel, but not the upper, nor the guides
ptt49er
Phillip
Wish I'd seen your tip on boiling them before you put them on. Mine were a BEAR to get on.
