Thickness Planers - How Thin??
Canuck
I have a DW735 planer that I have primarily used to thickness plane down to 1/4"-3/4" lumber. The depth turret is graduated down to 1/8th" It would seem to me that at that height, the knives are getting awfully close to the planer bed. As thin as I have planed is 1/4".
Has anyone ever thickness planed down to an 1/8" and would it be wise to use a planer sled if you need stock that thin? (No. I haven't talked the LOML into getting a drum sander..............yet! ....Have been watching Travis Porter's thread and don't think I am ready to risk that request just yet!!!:gar-Bi:gar-Bi:gar-Bi)
Just curious.
Thanks,
T
toolferone
User not found
I would use a sled for 1/8 inch stuff. With a long sled you should not have any snip issues either and you can double stick the piece down for extra support. Melamine works well for planer sleds.
I would use a sled too. I have planed down below 1/8" but used a flat board wider and longer than the piece I was planing. I just out the piece on top of the board and ran it in 1/32" increments.
gator
George
I have a DeWalt 733 and have/do plane down to 1/8". I use a sled but instead of double stick tape, I glued (glued not nailed) a strip of wood width wise across the top of the leading edge. This serves as a stop for the workpiece. I started it at about ¼" thick and as the workpiece planed down, so did the stop. It still works well at a little under 1/8" thick. This set-up also works well with short pieces. I recently had occasion to plane some 3/4" thick pieces that were 5-7" long. Lined them up end-to-end against the stop and went to town.
The one thing to look out for is figured, knotty, gnarly, or otherwise, sensitive wood. If it gets too thin it will have a big tendency to crack, split, come apart, shatter.
George
Bigdog72
Geoff
George
George,
Could you post a picture of your sled? I can't visualize what you have done.
DavidF
I do the same as George, I have a simple sled with a back stop or the piece can come zooming back at you! I would also agree that either double stick the piece down or make it at least 6" longer than you need, because eventually an end will catch and break off or at best get horribly chewed up.
gator
George
Just a piece of ¼" luan cut to the width of the planer bed. It could be any material, melamine, BB Ply, MDF or whatever. A ¼" of wood (if I recall correctly, poplar in this case) glued (no metal attachment method) across the top of the leading edge. This acts as a stop for the workpiece as the sled/workpiece is fed through the planer. As you work the thickness of the workpiece down below ¼" the stop gets thinner but still works (as you can tell from the pics, it is really thin now and still works).
George
DavidF
8/medium/1
George
Do you mean "on the leading edge" George? Mine is on the trailing edge to stop the pieces being pushed back by the cutting force of the blades...
gator
George
Don't know about your planer, but the DeWalt rotates toward the front of the planer thus pushing the workpiece forward against the stop and pushes the sled and workpiece through the planer. Yes, on the top of the leading edge.
George
DavidF
George
Now you've got me confused George! I have the dewalt and yes, the blades rotate towards the front of the planer (infeed) against the direction of movement so surely the forces are towards the front (infeed) of the planer? so my stop is on the trailing edge of my sled. I have to say that most of the time I just use an MDF piece to raise the bed of the planer that DOESN'T go though the planer and that has a stop on the UNDERSIDE of the trailing edge (towards the infeed side) so that the feed rollers don't pull it through. But for parts that seem to slide backwards then I put them on a sled with the stop on the top on the trailing edge and send the whole thing through as though it was one piece with the thin stock on the top.
This sounds like a discussion over a pint moment:rotflm:
gator
George
David -
I think that this is a semantics problem. Your sled stays fixed, in effect a part of the bed, in which case the stop would be on the bottom trail edge to keep the sled from going forward. With mine, the sled and the workpiece go forward as if one piece, thus the stop on the top leading edge to keep the workpiece jam up against the stop pushing the sled through with the workpiece.
George
DavidF
David -
I think that this is a semantics problem. Your sled stays fixed, if effect a part of the bed, in which case the stop would be on the bottom trail edge to keep the sled from going forward. With mine, the sled and the workpiece go forward as if one piece, thus the stop on the top leading edge to keep the workpiece jam up against the stop pushing the sled through with the workpiece.
George
A, ha! I see what you are saying now, Your front stop is to enable the feed rollers to feed the sled through, my back stop (on the sled that goes through the planer) is to stop the pieces being flung backwards by the BLADE rotation. In reality I guess there might be a need for a stop front and back? On yours, the piece "could" catch and come backwards and on mine the pressure from the feed rollers on the piece before the reverse forces by the blades kicks in, could slide the piece forward? Anyway, as I said, usually my sled stays put unless I am trying to flatten a piece wider than my jointer, then the sled is shimmed and goes through the planer - Phew, glad we got that sorted out - shame about the pint though:gar-Bi
gator
George
my back stop (on the sled that goes through the planer) is to stop the pieces being flung backwards by the BLADE rotation. In reality I guess there might be a need for a stop front and back? On yours, the piece "could" catch and come backwards and on mine the pressure from the feed rollers on the piece before the reverse forces by the blades kicks in, could slide the piece forward? - Phew, glad we got that sorted out - shame about the pint though:gar-Bi
I've never had a problem with the knives kicking the workpiece backward. I think the knife rotation keeps it going forward.
Let's not rule out the pint though. Could be maybe at the planned Durham lunch?:icon_chee:icon_chee
George
Canuck
Canuck
Thanks so much, guys!!!!:icon_thum
Sounds like a sled may be the answer for any really thin stuff. Never even thought about snipe when pieces get this thin! Now that wouldn't be too good .... not much wood left to try and sand it out.:BangHead:
DavidF
George
Hmm, not sure I am going to make it to Durham, it's a bit too far from Apex for a lunch, we'll see. Might need to wait until the picnic!
The only time I have had the piece really come backwards was when it was a thin piece that wasn't stuck down, the leading edge lifted off the sled after it went through the first feed roller and the blade caught it full on, smashed the front edge of the piece and sent it out the infeed side of the planer, not a normal event though I agree.
My DeWalt 734 states a minimum thickness of 1/8". The thinnest I have done is 5/32 (without a sled and no mishap or snipe, but I crept up on the final thickness using 1/8 turns on the adjustment). With thin wood, if is has a bow, make sure that the leading edge is bowed down when feeding it in. This helps prevent it catching the blades.
However, after reading this, I think I will be using the sled technique also if I do any more thin stock.
Interesting. I have never (knock on wood) had a planer kick or throw a board in either direction and I have had 3 different planers including a lunch box Makita. The issues I have had are the infeed or outfeed rollers don't grab due to a valley in the board or that the board gets "stuck" and I have to wiggle it left/right to get it to move.
DavidF
I think in my case it was a result of taking a avery light cut, so the feeder rollers were pressing only lightly on the piece and the end had curled up into the blade so the blade got a good hold on it. As I said, generally, my "sled" stays put and I just run the thin strips through as normal, not normally any problems either. Having the sled move thorugh seems to be not necessarily the easiest way, but horses for courses I guess? what ever works, is the best way!
Alan in Little Washington
Alan Schaffter
The sled with stops can help the stock from being flung out and will eliminate the problems caused by bed rollers, but there are a couple of other issues with planing thin stock that depend on the design of the planer.
The blades being close to or actually striking the bed is a non-issue.
Cutterhead and blade design and sharpness are factors. It is easier to plane thin stock with a segmented head like a Byrd Shelix.
Bed and feed roller design, pressure, and spacing can cause flex in a thin piece which is the problem. The stock can be pulled up causing unever planing or even buckle and get caught in the cutter with any number of negative results.
I think you will find that folks who do a lot of work with thin stock, like luthiers, only use a planer to get close, then switch to a drum or wide belt sander to achieve final thickness (or should that be 'final thinness'? :wsmile: )
DavidF
You're right Alan, as soon as I got my 16-32 drum sander I stopped using the planer for thin stuff. Even for thicker stuff I now just get it close and then finish off in the sander - This really IS a tool I wouldn't give away now! Expensive, but worth it I would say.
