Signature Issue
bsquared
Brooks
I uploaded a custom signature file from my PC. THe properties on the signature now say 500 x 64 which should meet the size requirements. Should not the signature show at the end of my post?
Am I having a senior moment? I checked for other "Signatue Issues" but I must be the only dummy!
froglips
Jim Campbell
Nope you aren't having a sr. moment! You are dealing with a more complex signature.
After you upload the pic, you then need to click on this link next to the image:
Insert Signature Picture
Then look in the text box above. You should see some html code that includes your image.
Let me know if this helps.
Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.9.2) Gecko/20100115 Firefox/3.6
Hi Brooks,
You're not having a senior moment, it's not obvious since it's a two step process. After uploading your signature picture (which you did successfully!), you need to click the link "Insert Signature Picture" that's beside the signature picture. This will insert the tags {SIGPIC}{/SIGPIC} in the signature text area above. That should make the image visible. Give it a try, if it doesn't work I'll see if I can make the adjustment for you.
Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.1.8) Gecko/20100202 Firefox/3.5.8
froglips
Jim Campbell
Ha, Bas! I got the answer in 29 seconds before you did!
You gotta get up pretty early to get the worm :)
bsquared
bsquared
Brooks
I tried the Insert Signature but I never get anything in the above signature box My original signitaure I loaded is a JPG. Is that the issue? It say it will take an image.
Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.0; Trident/4.0; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; WWTClient2; .NET CLR 3.0.30729; OfficeLiveConnector.1.4; OfficeLivePatch.1.3)
froglips
Jim Campbell
Look for the words SIGPIC in the box.
Do you see all the smilies and a text formatting buttons above the box?
bsquared
bsquared
Brooks
I never see the words SIGPIC in the above box.
I do see all of the smiley guys below the signature box.
Could this be a Vista issue?
froglips
Jim Campbell
For kicks, try typing a signature in the box.
Then click "Save Signauture" at the bottom.
Lets see if you can setup a basic text sig.
bsquared
bsquared
Brooks
That seemed to work. My text stayed in the box.
froglips
Jim Campbell
Try two different tests please.
First, try the Insert link and see if you get the SIGPIC.
If that doesn't work, then try to paste this in the text box and save:
PHP:
[SIGPIC][/SIGPIC]
bsquared
bsquared
Brooks
I went back to the top signature box and tried to change the font or font color and all of those seem to be disabled. thEY ALL WORK IN THE REPLY TO THREAD BOX.
bsquared
bsquared
Brooks
When I pasted the [SIGPIC][/SIGPIC] in the signature box my image magically appeared in the signature box. It must be magic! You are truly a wizard.
Thanks for all of your help!
