I guess this is a test results reply and a little extra. Maybe more than a little to add to the discussion.
From my earlier post I was comparing the Zinseer Seal Coat and some flake mixed shellac. The shellac I am mixing is a blonde dewaxed type. I mixed it to a 2lb cut to make the initial test equal in my simple way.
Questions:
1. Does the shellac have an adverse effect on the adhesion of the poly?
2. Is there a difference in the seal coat and the flakes?
3. Is the convenience of the ready mix worth the doubt/wonder about the age of the shellac?
4. Is there a price difference? Are you saving money with one over the other?
1. Does shellac have a negative effect under poly? NO. Why not err on the side of caution and use the dewaxed stuff like Seal Coat or dewaxed flakes. Skip the Amber/Orange shellac you don't need it. If you like the warm glow of Amber shellac with wax in it - just take your blonde shellac and add a little alcohol soluable dye to it. Same results and you don't have to buy 2 types. Cheaper. No wax to consider. Additionally, as another person mentioned- scuff the shellac lightly to increase the tack of the poly.
2. Is there a difference in the SC and flakes? Yes. Once you mix your own flakes you will immediately see the difference in clarity. The SC is cloudy from additives and the flakes after being dissolved are clear as glass. Which one do you want? Cloudy or clear. Yes its true that the SC does dry with a nice clear film -- how clear? Have you campared the two? I have. Sorry it wasn't significant enough to sway me one way or the other -- so that one is a draw.
3. Is the age of the shellac a concern? You bet on this one. Here's where the pitch for flakes can be strong. You mix up any amount you need at the time you are using it. The flakes I buy are such a good quality that I can grind them to a powder like form, pour them in a jar with denatured alcohol and the mix will be ready in 3 hours. If I am thinking ahead I skip the grind and put them in the jar over-night and they are ready in the morning. The shellac is good for about 6 months but... I might add it is not as good at 6 months as it is the first week of the mix. How do I come to that conclusion? Mostly sanding and drying experience. Something like this test.
Test Finding 27-28 Sept:
Shellac Flakes when sanded came off the board onto the 400 paper in dry powder. Seal Coat gummed up the dry sand paper. Yes the mix is easier and the results were clear on that test. I might add, both films were applied with a rag and both films were 2lb cuts. Is this important for me? No. I never sand shellac for results with dry paper. When I sand dry shellac I always lubricate the surface with a mix of mineral spirits and mineral oil in a small squeeze bottle. I shoot the stuff on the shellaced surface and sand with 400/600 paper to level or repair shellac defects. The paper doesn't clog unless it is bad shellac. After sanding, wipe down with mineral spirits, let it dry and you are ready to apply another coat of shellac. Repeat until you have the surface you desire.
So far I can't make a case for the SC.
4. Are you saving money by purchasing SC or flakes? I don't think so. Here's my thoughts:
You pay about 10-12 bucks for the quart can of seal coat. A gallon is 40-48.00
Flakes are 20-22 for a pound and the denatured alcohol is 15-16.00/gallon. So one is 48.00 for a gallon and the other is 38.00/gal. Big Deal.
Edit: the flakes are more expensive. I forgot: at the end of the flake mix you have a 1lb cut gallon not a 2lb cut like the cans of shellac. So the flakes will cost more. Hopefully you won't have to toss the unused stuff.
My 2 cents:
If you have some SC go ahead and use it up.. its good stuff. Next time try some flakes. I think most guys I have worked with that see me using the flake mix are encouraged to try it for their work. I don't know anybody who has gone back to the can.
Source:
http://shellacfinishes.com/
Hope this stirs up some thoughts. I inserted this as a reply and not a new subject so it would be buried in a thread for those interested in the shellac finish.
I am currently working the final leg of a desk project. This is the lid that I have NOT FRENCH POLISHED. The shellac is applied with a cotton rag dipped in shellac and applied like a brush. There are 4 coats at present - each sanded with 600 paper between coats. I will need to apply many more 1lb cuts till I get the surface I want.
So long
dan
danmart77
