In my previous thread about my new beast, I included some pics including the cleaned up left side and the yet to be cleaned right side. Here now are the before and after shots of the right side:
Before:
And after: (quite a bit nicer- almost new looking. Heck, the original paint hasn't even worn off the sprocket teeth yet!!!)
And if you are interested in how heavy-duty this thing is constructed compared to today's equivalent- in addition to the heavy castings that hold the cutter head and rollers, the upper frame is welded from 3/8" steel! The lower "sheet metal" section, including the big access doors, is a hefty 3/16" steel more like steel plating than sheet metal! The gray painted steel visible on the side of the bed is sheet metal bolted to the big cast iron bed. I haven't measured the thickness of the cast iron bed but the casting includes a 3" wide skirt all the way around it (under the steel panels.) No wonder this thing weighs over 1000#.
Question: Anyone have any suggestions for lubricating the chain and sprockets. On the OWW web site there is one recommendation to use dry grease to limit dust adhering to the grease. I have a spray can of Dry Lithium Grease already so may use that.
Before:
