Sawstop Pro unboxing (tool porn!)
merrill77
Master Scrap Maker
After way too many years of thinking about it, I finally bit the bullet today and picked up the SawStop Pro Cabinet Saw. The mobile base is a requirement in my shop. I opted for the 36" fence and the outfeed table. I also needed the dado cartridge and a ZCI for the dado.
BTW, they changed their blade insert design - it now locks into place with a lever. It looks like it could move up with vibration and hang up the workpiece, so it will be interesting to try that out.
They used a fork lift to load it into my van. When I got it home, I started wondering how I was going to get it out???
After unloading all the extras, I decided to remove the outer box (top) and try to take out any loose pieces (such as the cast-iron wings) to lighten the load:
After removing all the loose pieces, I realized I had been very lucky...and a plan formed for getting it out. They put the saw in top-first - meaning the bottom of the saw would be coming out first. So my plan was to install the mobile base and then see if I could then slide the saw out the back of the van and lower it, upright, onto the ground.
But first, I needed to get it out of the styro packing and onto something that I could easily slide over the threshold. The box top fit the bill, and I prepared it for the move:
Moving it actually turned out to be easier than I expected:
Then I slid it partly out an installed the wheels:
I thought long and hard about sliding it out of the van myself. But the possible irony of getting injured during that process was too much for me. I grabbed two neighbors and we slid it out effortlessly:
It was so easy, I think I would have been ok doing it by myself. I'm average height/weight. If your larger and stronger than average (and a bit brave), you can probably manage yourself.
Finally, here she is in my shop:
That is as far as I've made it so far. I'm really impressed with the packaging and instructions so far. Here is the packing of the wheels ("mobile base"):
But what really impresses me is the hardware packaging. Not only is the packing REALLY well organized and labeled:
But the package even has those convenient little individual tear-outs for each part, so you can take out only the one piece of hardware you need, when you need it:
And they are numbered in the order you need them! Nice. Kudos to SawStop. I have not seen anything packaged this nicely. Most of my tools are quite old...have other manufacturers (Delta, Powermatic, Jet) improved to this level as well?
Well, that is my progress so far...and it wore me out. I'll get back to it after I put the kids to bed. If anyone wants more updates, give me a shot and I'll take more pics!
cptully
Chris,
I must admit being jealous! SawStop first came out about 2 years after I bought my Rigid TS. I've always wished that I had a a SawStop rig, but cannot justify ditching the Rigid and replacing it with a more expensive unit (especially considering that I only paid $250 for my Rigid TS2424!). With that said at some point in the next 5 years or so I expect that I will upgrade to a cabinet saw, and will at least consider the SawStop.
Congrats and and enjoy, but please do not ever test the blade brake! Keep your fingers in one piece (each)!:gar-La;
Trent Mason
Trent Mason
Nice score! :eusa_danc:eusa_danc:eusa_danc
Reminds me of when I was unpacking my lathe by myself. I put the stand together and then stood there looking at the bed on the ground for about thirty minutes. I think it weighs somewhere around 200 lbs. I stood there for a long time and finally I got so angry that I just picked it up and sat it on the stand. Lucky I didn't get hurt doing it. Good call asking the neighbors. :thumbs_up:thumbs_up
johnstory
john
My sweet wife gave me the industrial SawStop last Christmas. It's been all it's supposed to be. All the things you've noted so far continue in performance. I've not tested the blade brake, but I do appreciate the easy to use blade guard and riving knife. Best woodworking!
drw
Donn
I know EXACTLY what you mean, I too was impressed with my initial SawStop experience. Indeed, putting the saw together proved to be a very enjoyable experience. Do to the exceptionally well-written manual, as well as the informative nature of the small-parts packaging, I never questioned if I was assembling the saw correctly. Congratulations on the new saw, it is a great tool!:thumbs_up
Donn
kave
Kettrell
"Hot" looking little number you got there Chris. Now go ahead and lay your "woody" on it!:rotflm:
manfre
Manfre
Congrats on the saw! I really like when the assembly parts are packaged like that. My Ridgid BS had that sort of packaging for the nuts and bolts, but the back was not labeled and they were not numbered based upon when I needed them.
merrill77
merrill77
Master Scrap Maker
I headed back down to the shop this evening to start assembly. First was to locate all the various parts I pulled out of the box. Everything except the 2 cast iron extension wings are shown here:
Next I pulled out the controller and electronics, which were neatly stashed inside the cabinet:
Again, the hardware is really well organized...in FULL COLOR this time!
Each of the colored section of hardware is referenced in the instructions...in color :> You'd almost have to be trying to screw up the assembly.
Next step was installation of the motor housing and the extensions. The rubber mallet helped to persuade the extensions to line up, but I still don't have them perfectly flush with the main table. I'll need to take another shot at this before I install the fence rails.
Finally...everything from box #1 is assembled!
Have I mentioned how good the documentation is? The spiral-bound manual is printed in full color! I've got some reading to do before I start on the fence.
The next section of the manual covers re-wiring for 240v, so I guess I'll be doing that before the fence. Time to hit the books!
CaptnA
Andy
Nice to see a set of instructions that are user friendly.
The sketch/schematic that was supposed to serve as "instructions" for my portable bench/stand is such a joke. It looks like a copy or a copy of a copy and is so blurred the drawing might as well be done in crayon.
Congratulations on the saw. Hope it serves you well.
FlyingRon
Ron
The only bizarre part is the instructions for putting the mobile base on AFTER you assemble the saw which involves tilting it up on the fence rails. That seemed way mickeymouse to me and I see you did it right as well and put the wheels on it before standing it up the first time. Moving it around is a lot easier with the wheels.
Of course, my woodworking neighbors decided to help me, so I didn't even have to do much to get mine set up. I did have a dial indicator and we were all set to align the thing when we decided it was better than we could hope to set it on all the measurements we made.
merrill77
merrill77
Master Scrap Maker
Interesting - the instructions I have note in several places to STOP and put on the mobile base if you have one - before putting the saw upright.
FlyingRon
Ron
Good, then they fixed it. I actually had correspondence with Steve Buss (the president of SawStop) over that issue.
MarkE
Administrator
Congratulations on the new saw! :thumbs_up
And I can see by the first picture in post #11 that you are still getting good use out of the old TS. :gar-La;
merrill77
merrill77
Master Scrap Maker
I got time in the shop tonight and mounted the fence. BTW, this is the 36" fence option. I started by opening the first fence box:
I unpacked the parts and laid them out. As with the saw packaging, the fence parts are well packaged, particularly the small hardware parts. These instructions are printed super-size - I feel like I should hang it on the wall.
Opening the second fence box, which contains the extension table, legs and related hardware:
First step is to mount the rails. My adjustable-height sawhorses came in handy to hold it in place during mounting.
Here are both the rails mounted:
Next steps include mounting the extension table between the rails and mounting the fence tube, both of which are easy thanks to great instructions. Add the fence and it's done!
Note that I didn't mount the extension legs. My shop floor is not remotely level, so I'd need to re-adjust the legs every time I move it...and I move it a lot!
Last step will be the outfeed table. It, too needs legs...I'm going to need design folding legs that mount to the saw cabinet so that it can be folded down when not needed. That should be interesting.
