I have a powermatic 87 bandsaw, birthday is 1967. Its the metal working version of the Powermatic 81. Its basically a more robustly built version of the 81.
It has a 3ph 3hp motor on it now and i was planning on just getting a phase converter because i also have a Powermatic 68 12" tablesaw thats also 3ph, but I came across a 5hp 220 motor that has the same rpm, and found a similar 5 hp motor that has more or less the same rpm and hp as the 3ph motor on the tablesaw (+/- a couple 100 rpm) that together are less than the cost of the phase converter, not by a lot, but enough that I'm now leaning toward just swapping them out.
The problem is that I cant make sense of all these different motor factors... is a compressor duty motor adequate for these 2 applications? Farm Duty? What the hell is a "service factor" ? Is higher or lower number better? Whats the range im looking for? Duty cycle? Continuous? Common sense says yes, I want a Continuous duty cycle i guess because it will always be under load when its running? What kind of torque numbers should I look for? Is 15ftlbs good enough for a bandsaw or should it be higher or lower? Also, there are all these different motor start options, hard, soft, single or multiple capacitor, digital this or that.....
ugh....so out of my element with this stuff and the last thing I want to do is toss 900 bucks in the garbage for 2 motors that fall short of what I need.
I should mention that the bandsaw will be pretty much exclusively used for resawing hardwoods with a 1.25" blade. I am not concerned with it not being able to handle the extra hp or torque, the thing is a tank, its literally 1800lbs...the guide bar alone is about 30lbs and its no joke just a 30" long 2"x1.5" block of solid steel.
Any help is appreciated, thanks for reading
