pencil Kit
gsdoby
Gary
I recently tried to make a slimline pencil but am having trouble with it. It is sticking and will not advance the lead. Is it an alignment problem. I think I put It together correctly. I have never hadany problems with the pens. Any thoughts would be appreciated.
D L Ames
D L Ames
Gary, Sometimes the lead gets fouled up in the prongs at the tip of the pencil and will cause it to jam. I normally pull the eraser end off, pull out the excess lead, then unscrew the tip to get to the prongs. Check the prongs and if needed use a needle or pin to push any lead back into the chamber. This normally will do the trick unless the pencil was assembled incorrectly.
D L
