Need New Drill [Big one]
When I do a bunch of boring through any metal above 1/8" I use a Mag-drill. You can rent one and buy bits is a way to go. If you want annular bits that will last pretty good, then the one below are decent.
The DIY annular set below will allow you to cut with a regular drill- the Milwaukee drill mentioned by Bill Clemmons, I have and it will work excellent. But if you are drilling a boat load then the annular will be way easier on you.
The Last thing I linked is the Vevor mag drill. I have used this one and a couple other of their tools, they do work ok, but not built for the heavy duty work I do, but they will last long enough to make the purchase worth it. My Caveat....... every time I buy a Vevor cheapo tool, I am happy it works as well as it does, but it still feels like I am spinning a roulette wheel with every purchase.... just sayin'
Some options.
Full Mag Drill Set
Pro Bit Annular
DIY Annular
tri4sale
Daniel
I'm planning to replace the deck on my 18' flatbed trailer and I don't think my little 20v Dewalt drills have the power needed to consistently drill thru the steel. (At least not without having to constantly recharge batteries)
Any suggestions on how big/powerful of a drill I'll need to keep this project moving as quickly as possible. I can do the work in my carport in front of my shop, so I have electricity. I'm thinking for a one time need a corded drill will be the more economical way to go. But, open to your thoughts and suggestions. (I've done no research yet)
I don't use my trailer often [obvious from photo] but when I do, I need it to support a 6500lb tractor. :) View attachment 231074
I used one of these to replace my trailer deck a couple of years ago. Drilled a pilot hole then drilled it to the size I needed for the bolts. Used my Ridgid 18V battery drills, had pilot bit mounted in one and step drill bit in the other, didn't take that long to do.
Two other options for others is to purchase some 2" x 1/8" or 3/32" hot rolled steel and over weld it onto the existing channels, or a 1-1/2" x 1-1/2" x 1/8" or 3/32" angle iron welded opposite the top leg. It only needs welding about every 8" with a 2" bead.
charlessenf
(;harles
I've found my old wired drills do just fine through steel. I have several Lithium Battery Drills and tools but never threw out my corded tools. If you're near Lenoir, I'll loan you a few - and my Drill Doctor 'cause no drill works well with a dull bit in it - you supply a bit of oil or a bar of soap
Looking at the trailer, it appears that there are boards on it presently. How are they attached? If with screws or bolts - might the process of removing the old reveal the holes necessary for attaching the new?
