Making Colonial Shutters
mgoins
Marvin
Or, stated another way, “What to do with the molding, scraps, and 3 1x8 old growth pine boards left over from paneling our Reading Room? We’ve wanted Colonial type shutters for our home for several years, but, their considerable expense was prohibitive. But, we have a shop now! And, the will to try it.
This thread will document the quest to build a set of Colonial Shutters for the window that matches the paneling in our Reading Room. By the end of the quest, we’ll see if the will survives to continue on through the rest of the house.
Below are a couple pictures of the Reading Room. Here’s a link to the entire story of the Paneling Project: http://ncwoodworker.net/forums/showthread.php?t=28394
West Wall:
South Wall:
Here’s what we’re shooting for. I snatched this vintage example from the curb a few months ago.
Louvers will be: 1 ¼” x 5 5/8”. Looked at using the Woodline Shutter Set, but they’re Out of Stock for 2-3 weeks, and I have 2 weeks of vacation. Decided to see what I do with what I have.
Here’s a pic of the stock pile to be used. A tremendous amount of shorts, and cut-offs from the paneling project. Should be just enough...
Step 1 – Resaw to split the stock in half, 21/64”.
Step 1 – Resaw Complete
Step 2 – Plane to 5/16” thick
Step 3 – Form Louvers on table saw. Blade is tilted to 5 degrees.
Step 4 – Roundover completed.
Started the project on 12/20/2010 with machine setup. 4 machines were tuned up, jigs made, and set up for producing the louvers. Plus, installation and setup of the mortise attachment on the drill press, and Tenoning Jig on the table saw for production of the rails and stiles.
At this point, the frames & stiles are rough cut, and all louvers formed.
Next steps:
- Jig for drilling louvers for shutter pins.
- Adjustment Rod
- Jig for attachment of louvers to adjustment rod
Thanks for playing along.
Instead of drilling for pins, why not make pins on each shutter leaf? Make a jig, and using a plug cutter, cut pin out. Then using TS, or BS remove the waste just like you do for a tennon. You might have to do some clean up with a utility knife.
mgoins
mgoins
Marvin
Have never used a plug cutter. Do you think a plug cutter would cut smoothly enough to not blow out, I'd prefer to go all wood, if we could figure out how to do it.
mgoins
mgoins
Marvin
12/27/2010 – Jig Day
Out in the shop by 7am, first order of business was roughing out the adjustment rods, using the same setup as the louvers, just without the angle cuts. The scrap pile is now down next to nothing, with the bin looking closer to toothpicks & sawdust. Every stationary tool and small clamp in the shop has been put to use.
Adjustment Rods
Router Table Setup. 3/16” roundover bit. Fingerboards are made from reclaimed door frame.
Next up were jigs. Drill press is a 1953 Craftsman 15” with an Atlas W68 Universal Vise – almost sold the Vise a year or so ago – guys on OWWM made me aware of what I had – glad I held onto it.
· Stile Drilling Jig - Need a jig to control drilling evenly spaced holes along the length of the stile. 1” apart. Example shows using 2 1/8” drill bits, one in the drill & one in the ‘spacer hole’.
· Louver Drilling Jig – is setup to drill a 9/64” hole in the meatiest part of the louver to accept the shutter pin.
Stile Drilling Jig:
Stile Drilling Jig – up-close
Louver Drilling Jig
Looking into adjustment rod installation, I’ve seen a couple options. Let me know your thoughts on this.
1) Staples. At this point, I don’t have a stapler, or air compressor, and though I know I should use this opportunity to add tools to the crib, I’m thinking of going a different route. Also, since we’re using old growth pine with knots, and relatively thin stock, I’m nervous of hitting a knot on the adjustment rods, blowing out, and ruining the project.
2) Screw eyes. I’ve seen a couple people online use 1/8” brass screw eyes & they seem a step up from staples.
Sealeveler
Tony
Thanks for the play x play.Like your jigs too.Drill press is a winner,especially with the vise.
Tony
mgoins
mgoins
Marvin
12/28/2010 – Man, is it cold outside… 9 degrees here in East Tennessee. Most of the snow from the weekend is still on the ground. Hate to say it, but, I didn’t jump up excited to get hit with the shock of the cold to warm up the shop this morning. Went out about 8:30a.
Noticed yesterday that the Stile Drilling Jig was off slightly, due to the X-Y table on the vise not being aligned properly with the bit. Spent quite a bit of time this morning, working on alignment. After quite a while of sighting by eye, and continually being off like before. Came up with using the drill bit to align the jig, lower the drill press all the way & run the face of the jig across it, but it too flimsy and would bend. So, I remember I had an alignment pin from replaced it with the mortise attachment alignment pin, and it worked like a champ.
Here’s a pic of alignment pin – basically a large piece of drill stock.
The finished product on a piece of scrap.
At this point, I think I’m done for a little while. Need to order a 3/16”D edge beading bit, the shutter pins, & screw eyes. ‘Til later…
Glennbear
Glenn
Your reading room is fantastic looking Marvin, thank you for keeping us informed on your shutter project. Although I have never made a set, I like the idea of the screw eyes vs staples also. :wsmile:
mgoins
mgoins
Marvin
This week saw the arrival of a few parts required for the project, just in time for the weekend.
- a 3/16"D Beading Bit from MLCS
- Qty. 400 #217 1/8" brass screw eyes from Woodcrafter.com. Great prices - $1.60/100.
- shutter pin samples. Have found a couple options to pick up shutter pins in bulk. E&T Fasteners ($15 minimum), and Outwater Plastics ($25 minimum). Hopefully, once pricing is known from E&T, I can get an order placed with of them on Monday & have them by next weekend.
Made a little progress today...
Flipped the Stile Drilling Jig around & added another jig to drill the holes in the louvers for the Brass Screw Eyes. 1/16" bit.
Delta Tenon Jig setup to cut the tenons on the Shutter Rails. Got the Jig on clearance at Lowe's for $25 a couple years ago. This is the first time it's been used. Worked pretty well - but, wished I had one of the vintage cast iron Tenon Jigs - maybe one day...
Tenons Cut ready to go.
Things ought to begin coming together next weekend. Til later...
Your jig is cast iron, just not as massive as the old ones. I had a problem with mine wanting to tip, so I solved that problem.
mgoins
mgoins
Marvin
Sorry for the confusion - meant I'd like to have one of the vintage Delta Tenon jigs. This one wants to tip too. How'd you go about fixing the tipping problem?
b4man
Barbara
This is a fantastic thread! Thanks Marvin for the time and pix you have put into this project.
Barbara
mgoins
mgoins
Marvin
01/16/2011 - This week saw the arrival of the last parts required to complete the project - Shutter Pins. Further progress had been hampered waiting on them. They arrived just in time for the weekend.
Ordered them from Outwater Plastics. They will sell to the public in bulk, $25 minimum. Even so, quite a bit of money was saved over buying retail, and enough left over to do a few more windows.
- Qty. 1000 Shutter Pins - Part# SP-1
- Qty. 1000 Tension Control Pins - Part# SP-19 (am planning on using these every 5th louver & see how they do).
Was excited to get out in the shop today - but, there was a sense of foreboding. Considering the project is made from old growth pine scraps, and is to match existing panelling made from the same stuff, i can't down run down to H*me D*pot to pick up another board. One major mistake & it could be game over.
Drilling the stiles for the louver pins is probably the most important operation of the project, as the eye could follow inconsistencies in the pattern. Took an hour to test drill a couple of test boards, & noticed that the drillng jig was allowing the holes to 'walk' away from the witness marks drawn on the board. The 'pin' was so tight, that it was hard to tell when it was in the previous hole. Ended up marking all stiles & sighting by eye. Worked out really well.
Using the louver pin jig to drill the holes
Cutting Mortises in the Stiles
Louver Holes Drilled - the 'extra' holes will be covered by bottom rail - Whew!
A little 'loose tenon joinery' to fix where I mortised to the wrong line... - Whew!
Adjustment Rod Slot Cutting Jig
Rails ready for installation
Next the Miter Box was set up w/a stop block to cut test louver stock at 5 5/8". Didn't want to waste the good stuff, if there was a problem.
Next the 24 louvers were run thru the louver drilling jig to drill for the pins.
The moment of truth...
Am proud of the result so far. This is the most challenging woodworking project I've ever done. Every tool in the shop has been put to use & there have been times I wished there was a 3rd drill press & a 2nd router table to use.
One down, 7 more to go...
mgoins
mgoins
Marvin
Can’t believe it’s been a month since the last update… Shop time has been hard to come by lately. The snow brought out snowboarding interest in my kids, been on the slopes at Winterplace in West Virginia, or Wolf Ridge in North Carolina the last 3 weekends.
Got out in the shop early this morning to see how much progress could be made today. Got quite a bit accomplished - one more day, and we’ll be ready for a test fitting all of them. Nearly everything’s been made & is ready for assembly. The exception being the adjustment rods, they need to be cut to size & the recess made in the top rail for them to rest. Hopefully, we’ll get to that tomorrow afternoon.
Chopped what seemed like a gazillion louvers today. Actually, the project calls for nearly 200. 24 louvers per section on the bottom, totaling 96, and 23 louvers per section on the top, totaling 92.
Louvers galore… These have been drilled for pins on each end.
Another view – thought this looked interesting… These have just been drilled in the center for screw eyes to attach to the adjustment rods.
Stiles drilled for louvers with mortises cut, rails rabbeted.
Getting there…
MarkE
Administrator
Now that this has been re-opened, please give us an update. This is a great project to watch.
mgoins
mgoins
Marvin
Good evening, Mark - our posts passed in the mail. Not sure why the first page of the post, shows up on the 2nd page, though - strange.
Thanks for watching.
Marvin, I don't think pagination has anything to do with a post being reopened, rather it is a function of the available memory for screen size relative to scrolling properties of the software.
At least that's the best lie I could come up with that sounded like geekspeak. :gar-La;
mgoins
mgoins
Marvin
2/26/2011 - Got out in the shop early this morning. Worked an hour here & there all day. Made a little progress. Learned to use a plunge router - have had it (P-C 890) for probably 5-6 years, but never had a reason to use it til today. Worked really well once I got used to it. Used it to cut the recesses for the adjustment rods on the top rails of each shutter section.
Adjustment rod recess jig. It's sized to cut a slot 3/8" wide x 5/8" long, using a 1/2" template collar w/a 1/4" straight bit. I don't have a vise... Thank goodness for that Atlas X-Y table vise...
Rails with recesses cut.
Shutter Parts sanded and ready for a little A-ssem-bl-y...
We're getting there...
mgoins
mgoins
Marvin
02/27/2011 - Sunday afternoon - Cut mortises for the hinges. Added a hinge mortise template to the adjustment rod recess jig - laid it out to cut both mating surfaces at once - saves a lot of time & ensures the hinges mate up correctly.
Hinge Mortise Jig
Shutter Frames Assembled
First real one - assembled - 7 more to go.
