Make a vise out of a ball screw?
eyekode
Salem
I was wondering if anyone has ever made a wagon wheel vise or similar out of a ball screw? They could definitely take the load but can they take the dusty environment?
Just wondering because I came across these: http://www.sciplus.com/category.cfm/subsection/19
18" long, 1x4TPI ball screws for < 10$.
The goal is to make something like: http://benchcrafted.com/vises.htm
How would you attach a handle? Turn down the end and use a setscrew? It would also need some sort of garter right? Not sure how that would work... Any suggestions on how to attach a garter to a piece of allthread?
I assume the thread on this would not fit any typical nut, otherwise it would be a screaming good deal :).
Salem
froglips
Jim Campbell
At that price, I'd leap then look :)
You can get acme threaded rod, but the cost of 1" would be more than my little mind could contemplate cost wise.
I'd suspect the movement won't be as smooth on the ball screw, but heck, its a vise. Do you need something so perfect to pinch a board?
You might play with them in one of those Schwarz "Joseph Moxon's Double-screw Vise"
Bernhard
Bernhard
Don't think that will work. A ballscrew is designed for efficient transfer and reduction of friction. Unless you hold the handle, the ball nut will move in direction of the force applied, so can't 'tighten' a work piece.
Cheers,
Bernhard
eyekode
eyekode
Salem
The fact that I have never seen a ball screw used by a vice made me think I was missing something :). Thanks for clearing it up!
Salem
eyekode
eyekode
Salem
https://www.surpluscenter.com/item.asp?item=1-3029&catname=electric
This looks like about the cheapest source of ACME thread + a nut I have found. Still not sure of a good way to make a garter. I guess you would turn a shoulder on the end of the rod, and fit the garter just larger than the end you turned down. Then attach the handle, but I guess the handle would need some sort of key to transfer the torque without slipping. Maybe welded on?
