How do you get these things level with the main table and how much variance is acceptable? I started by inserting the bolts and snugging them up, then tapping the wing with a rubber mallet on the top and bottom until it felt like it was the same level as the table. I checked for variations in table height by running my fingertips back and forth over the seam and tightened the bolts when it felt level. I can still feel that a seam is there so I'm wondering if I'm doing this incorrectly.
I don't have a straightedge but is there a way to measure it using a dial guage and magnetic base (one of those articulating arm bases)? Or am I just supposed to get it as close as I can using the "run your hand over the seam method"?
Thanks.
Thanks.
