Doug----------take the length of the wall and convert to inches, divide by 16, add 1, that will give you the number of studs for a solid wall. If you need top and bottom plates (which you probably do) multiply the length of the wall by 3-------that will give you linear footage for a single bottom plate and double top plate. You may be able to do with a single top plate if it is going in an existing building with a ceiling and is not a load bearing wall. Add 4 studs for each door to use for jack studs (studs that come up under the door header) and doubling the jamb studs that go full height. All these pieces will be 2x4. I like to use at least a 2x6 for the door header, if it is load bearing I use a 2x10 for the header. Headers can be made like a box beam from 2x4.
Hope this helps-----It may be good to check your local building code also.
Jerry
