Put your entire shop on wheels! These are not your run-of-the-mill casters. Features include easy rolling, non-marring, polyurethane tires which will not “flat spot” during long periods of remaining stationary. Both the swivel and the wheel ride on ball bearings for smooth rolling and turning. The double brake locks both wheel and swivel rotation with the touch of a toe. Unlike cheaper casters which only lock the wheel and allow the supported load to move around as the caster rotates on its base, these provide a rock solid base. The 3" casters are only 4-1/8" tall. Load rating for each caster is 300 lbs.
$10.99
