Okay, a couple of weeks ago I ask for advice on repairing a mistake I made when I rubbed through a lacquer finish on the edge of a project. It turned out that I was able to apply 3 more coats of lacquer and (carefully this time) rub out the piece again. The final finish ended up mirror slick and very reflective.
I have another small Christmas project made from ribbon sapele. I have not worked with sapele before and didn't realize how much open grain is in this wood. Again, I want a rubbed, gloss finish on the project.
I decided to filled the pores by wet sanding with a 50% or better reduction of boiled linseed oil with 320 wet/dry paper. Now I'm trying to decide whether to finish coat with super blonde shellac or spray vinyl sealer and finish with gloss lacquer. Both would be rubbed out in the end. I am running out of time and my thought is the shellac finish will build faster if I brush apply versus spraying the lacquer.
The boiled linseed oil has been allowed to dry for 4 days inside the house with heat and low humidity and is ready to finish.
If you recommend shellac, what cut would you use for the finish. I make my on from flakes.
Any ideas or advice on this would certainly be appreciated.
Terry
Terry
